C6?
Old Mar 17, 2005 | 12:26 PM
Jamie Miles's Avatar
Jamie Miles
C6?
Ok, I have a 71 F250 that I want to put a 351W in, but it came with a 360/C6 and odviously I would have to change the tranny.
I picked up a 78 E150 van with a 300 I6 for 50 bucks for the whole van. The transmission in this van does not have a removable bell housing, it is all one unit. Is this a C6? I have been told that if the whole transmission is one piece, with a non removable bell housing that it is a C6. So if I put this 351W in my truck, Could I use this transmission from this van without any problems? The way I understand it 300's, 302's and 351W's have the same bolt pattern.
The van runs terrible, but it does drive. It "bucks" up and down when you put it in gear and try to drive it when it's cold, but when it warms up it drives normal and shifts through all gears fine. I'm guessing that means it needs a new torque converter? The van also has a 9 inch rear. C6/9 inch with a 300 in a van, seems kinda like a odd setup to me.
I'm not new to swapping engines and stuff, but I am new to mixing and matching parts like this. Just trying to get my old truck back on the road again. Thanks!
Sorry if this is in the wrong forum, I'm a newbie, but I am asking about the transmission.
Old Mar 17, 2005 | 12:33 PM
smoke n tires's Avatar
smoke n tires
i would say its a c6, the trans should work fine and yes i would get a new tc, and replace the tc seal in the pump. shouldnt have any problems with this swap.
Old Mar 17, 2005 | 11:50 PM
Jamie Miles
I appreciate it.
Old Coyote
20
May 27, 2013 03:41 PM
Q's 86
Nov 19, 2008 08:07 PM
Chad M
Oct 20, 2006 06:31 AM
captainkirk
Sep 20, 2005 10:00 AM
GrayZee
Aug 31, 2003 09:41 AM
