they are only on the inside, same door panel, as other trucks. My Bronco Buckets came out of an '86, they have the arm rest on both sides, but interfer with the door panel slightly.
so the door panels on the broncos dont have the arm rest there? i should just be able to get some door panels off a bronco then.....new door panels wouldnt be too bad its about time for some.....any leads on the door panels other than the junkyards? i bet i could get an upolstery <cant spell.....shop to modify the existing door panels but i bet that would be $$$$
the seats and air suspension bases run about $1700 shipped to me.
I didn't look at the door panels when I took the seats out, but like I said it was an older bronco, '86. my uncle has a '95 bronco I can maybe go look at later today. my buddies '96 half ton has captains chairs and it only has one arm rest. maybe that clears it up a lil.
Like i mentioned earlier, I have a 86 f250 with captains chairs and they have armrests on both sides. The one on the door side rubs up against the door panel but works fine.
I just looked at my 94f350 door panel compairing the two. The panels look like they are the same as far as depth in towards the cab. It looks like the captains chair would go in the 94f350 and have the same ammount of room as it does in the 86 f250.
I had an '85 Bronco XLT w/captains chairs,each seat had 2 armrests and the standard door panels(with armrests).I've been looking for a set of these captains chairs for several years,if you find an extra pair,please let me know.
im actually geting national seat sportsters. there really comfortable and the price is reasonable. im getting them from buytruckstuff.com with the air suspension bases
