Engine missing .....?
Old Jan 20, 2006 | 12:39 PM
gsxrraycer's Avatar
gsxrraycer
Before I get into the problem, just wanted to say happy new year to all the FTE people. Its been a while since I've posted or been here. I had a lot of TSB work done on my truck that I"m going to list and then get to the new problem.
I seem to have gotten a truck that I could have lemon lawed with no problem, but the problem is.... when its running right its a freaking awesome truck.
My 2004 F150 has had the upper AND lower control arms replaced, rotors and brakepads in the front replaced, emergency brake cables replaced, rear rotors replaces, clutch packs, CD changer replaced, a frame dampner installed (which only minimized the shimmy not eliminated it), and with only 21,000 miles on the truck, my tires are completely bald. And yes I rotate them every 5000 miles, but i attribute the rapid wear to the fact they are ****ty tires and I've had this damn frame shimmy since day one. And since it only happened either at highway speeds or during braking, it was something I chose to live with. Its now getting worse again.
The new problem is, that now when accelerating while the vehicle is cold, at about 50 to 60 mph right after the 2nd to 3rd shift the things starts to buck like its misfiring. Once the truck warms up, it does it about 70 -75 mph. OR anytime I have to accelerate and it kicks down to 2nd and then shifts back up to third. I'm pretty sure its not the shift that i'm feeling. cause you can see the rpms drop and then shortly after it acts like its starving for fuel. Then after it hiccups a few times it sorts itself out and then acts normally. I thought maybe I got some bad gas, but its been happening now through 3 tankfulls of different brand gas (mobil, exxon, and Arco), and I've even taken to adding octane boost to see if that would help. It didn't.
Has anyone else experienced this. When my truck was in the shop in august getting all the upper and lower control arms done, the technician asked if i was having any engine problems. I looked at him and said "dude you're kidding right, i'm here for this and your telling me i'm going to have more problems?" Well i guess he was right.
I can't find any TSB's describing this problem, but see a thread about slipping transmission. I"m ALMOST positive thats not the problem i'm having, but then again I could be wrong.
Any help or suggestions would be greatly appreciated. The dealer has had my truck a total of 21 days in the 1.5 years i've owned it. If they have to take it for an extended period again, they are going to end up keeping it cause I'm going to lemon law it.
Thanks in advance
Last edited by gsxrraycer; Jan 20, 2006 at 12:58 PM. Reason: so it stands out more..... no one is reading it
Old Jan 20, 2006 | 12:45 PM
gsxrraycer's Avatar
gsxrraycer
I forgot to mention it seems to happen most when i'm climbing a grade, but not only then. It seems to happen worse going uphill. So maybe a fuel pump problem?
Old Jan 20, 2006 | 01:19 PM
gsxrraycer's Avatar
gsxrraycer
ok, i was just messing around in my driveway and had the truck running. At idle, it almost feels like there is a slight miss. Not all the time, but you can definitely feel its a little rough. I just thought I'd add this info as well to my post so that anyone else might be able to give me their thoughts.
Old Jan 20, 2006 | 04:14 PM
gsxrraycer's Avatar
gsxrraycer
Angry
Sorry for being such a pain about this, but I just got home from having to drive around and run errands. The engine light started flashing and then the truck died on me. It started right back up, and I was able to drive, but the engine light kept flashing. After flashing for about a minute, it stopped flashing, however the truck continued to run rough. You can see the Tach jumping around while the rough running is occuring. The manual says a flashing engine light means an emission problem, and to drive in a moderate fashion.
What on earth could a truck with only 21,000 miles on it have as far as emissions problems?
thanks
gsxrraycer
Old Jan 20, 2006 | 05:02 PM
sick150's Avatar
sick150
my truck was just in the shop 2 days ago for 2 bad injectors. it started idling messed up then when i went to drive it the check engine light started flashing, so i just shut it down. you may only have 1 injector bad so it doesn't seem as bad
Old Jan 20, 2006 | 07:39 PM
jdew1920's Avatar
jdew1920
The light coming on at all means emissions related problem - EPA makes them do that. Flashing light means a misfire.
Old Jan 21, 2006 | 11:20 PM
gsxrraycer's Avatar
gsxrraycer
I'm back......
the engine light is on all the time now. I'm bringing the truck in Monday. I don't have an appointment, I'm just going to go bitch at the service manager till he gives me a rental (oh yeah the dealership I got the truck from says their policy is no more rentals since Ford Corporate doesn't reimburse them for it).
I've already called a Lawyer who specializes in Lemon Law. I have a buddy that I play softball with who works at a different ford dealership in San Diego. He says Ford's going to fight me tooth and nail to not take it back, cause of all the buy backs they have had to do with the Diesel F250's and F350's.
This could get ugly. But I'd be happy if they just got all the stupid problems fixed and gave me the truck that I should have gotten when I put down nearly 40 grand for a truck.
Suddenly, I'm not so sure I'm going to stay a Ford man.
