Fuel or Computer Problem?
Old Jan 20, 2006 | 11:18 AM
Redwinkle's Avatar
Redwinkle
Question Fuel or Computer Problem?
One month ago I replaced both batteries. Last night I had a battery Light on and replaced the alternator this morning. I started the truck everything fine ( no warning lights)and let it idle for about 15 minutes while I washed up to go to work. About 1 mile from home the truck lost power and won't restart. Cranks fine, just won't run. I disconnected/reconnected the batteries and got the same results. Also drained the fuel bowl once again, won't start. Any insights would greatly appreciated.
Old Jan 20, 2006 | 11:28 AM
PSNut's Avatar
PSNut
As it's cranking over do u see the tach move. Might be your CPS.
Nut
Old Jan 20, 2006 | 03:34 PM
Kwikkordead's Avatar
Kwikkordead
That was the first thing that came to my mind as well, bad CPS.
Old Jan 20, 2006 | 04:24 PM
Redwinkle's Avatar
Redwinkle
I went back to the side of the road to answer PSNuts question about the Tach and the Tach did move----because the truck started!!! Is the Cam Positioning Sensor likely to be intermittent like this? The truck is back at home now.
Old Jan 20, 2006 | 04:37 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yes it can act up for a short time, and then start (like what happened to you) or not work. they are very finicky, and you could not see a problem with it for the rest of the truck's life. it could go out in 5 miles, 50 miles, 500 miles, etc. it has a mind of it's own. i would recommend picking up another CPS, installing it, and keeping the stock as a spare in the glovebox so you wont be stranded again.
dont go with another stock CPS, upgrade to a DT466 CPS. search this forum for "IHC Blue CPS", a thread that was posted to recently. a bit of good reading for the CPS-newbie.
Old Jan 20, 2006 | 06:03 PM
Redwinkle's Avatar
Redwinkle
strokin_it7.3-- I did just that. I found pics and a dealer that is open until 11pm. Thanks to you, PSNut and Kwikordead for your help. I'm confident that this is the fix I was looking for. The beer is on me!!
Old Jan 20, 2006 | 06:07 PM
PowerstrokeJunkie
The beer is on me!!
LOL im 16.
anyway glad to hear you have your problem fixed. how you like the new DT466 CPS?
Old Jan 20, 2006 | 06:11 PM
Redwinkle's Avatar
Redwinkle
Root Beer ?
Old Jan 20, 2006 | 06:23 PM
PowerstrokeJunkie
ill "try" the hard stuff
