please help with vin decodeing
Old Jan 19, 2006 | 11:23 PM
fordann76's Avatar
fordann76
Unhappy please help with vin decodeing
where on line or on this website can i go to decode my vin number????
please help
Old Jan 19, 2006 | 11:38 PM
fordann76's Avatar
fordann76
Smile this is what i do know about it
i do know it is a 89 F 250 2wd supercab long bed 7.5 v8 460 auto w/3 speed trans what i am looking to find out is what gear the truck came with from the factory i can not find the tag on the rearend also here is the vin if any one can help 1FTHX25G5KKB54629 thanx for any help
Old Jan 19, 2006 | 11:51 PM
76 F-150 390FE's Avatar
76 F-150 390FE
welcome to FTE
it would be on the sticker on the drivers side door post. it will say axle code and then a number or number and letter under it. you could also jack up one side of the rear end put the tranny in neutral CHOCK THE WHEELS! and mark the tire and drive shaft, count how many times you have to turn the drive shaft for the tire to make 1 complete turn. 3 and a half turns is 3.50:1
Old Jan 20, 2006 | 02:12 PM
ford4.9's Avatar
ford4.9
1FTHX25G5KKB54629
1FT- truck complete vehicle
H- hydraulic brakes, gvwr- class G, 8501-9000 pounds
X25- 4x2 extended cab/ supercab f250
G- 7.5 v8
5- check digit
K-1989
K- Kansas City: Claycomo, Missouri
B54629- yours 54629 truck built in B series.
Old Jan 20, 2006 | 02:15 PM
76 F-150 390FE
sorry! i read the post wrong i thought you said gears as in rear end gears and not gear. what info specifically are you looking for? drive train info will be on the sticker on the door post.
Old Jan 20, 2006 | 02:16 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
Had you posted in the 87-96 truck forum you would have received the info sooner than you did.
This forum is for those topics that don't have a regular place to post them.
There is a VIN# decoder in the Tech articles.
https://www.ford-trucks.com/article/...r_Decoder.html
Access is through the link in the bar near the top of the page.
The rear axle code is NOT addressed in the Vin #, you will need to post all the info from the Rating plate sticker
Old Jan 20, 2006 | 02:39 PM
fordann76's Avatar
fordann76
Smile thanx everyone
wanted to say thanx to everyone that post a reply i now know where to find out what gear is in the rearend of the truck thanx again
Old Jan 20, 2006 | 09:06 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...88#post3272088 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 87-96 F-Series trucks forum.
See ya on the boards!
-Matt
