Is there a quick fix?
Old Jan 3, 2006 | 09:30 AM
harmdogg1978's Avatar
harmdogg1978
Exclamation Is there a quick fix?
I have a 1989 F150 2wd 5sp witha Inilne 6 300ci. I have antifreeze comming out my tailpipe and I figured that my headgasket was blown, or I had a crack in the block. I got some silver seal to try and fix it but havnt dont that yet. Do you think it will help? what else might I try before I tear down the engine?
Old Jan 3, 2006 | 10:05 AM
quicklook2's Avatar
quicklook2
get a compression check.
do you think silver seal is the answer? i don't.
Old Jan 3, 2006 | 10:07 AM
Thomasm67's Avatar
Thomasm67
All that is a temporary fix it'll work fine for the short term but only short term i would find out soon as possible if it is the head gasket or block and get it fix ie=new head gasket or new /used block.
Old Jan 3, 2006 | 12:08 PM
smecomark1's Avatar
smecomark1
You may want to check engine for proper vacuum, if it is not low enough it can pressurize the the top of the engine and force coolant out. Would indicate an intake gasket leak or other large vac leak. I just had this happen, got lucky and found the problem.
Good luck
Old Jan 3, 2006 | 12:16 PM
quicklook2's Avatar
quicklook2
like smecomark1 and i are saying. you need to find out what is wrong before you start trying to quick fix or rebuild engine.
do a compression check. hook uo a vacuum gauge if you have access to one. check plugs and oil for signs of problems.
andym's Avatar
andym
I would steer clear of dumping anything into the engine. Find out what the problem is and fix it before you end up needing a new motor.
Old Jan 3, 2006 | 07:18 PM
harmdogg1978
Thumbs up
thanks guys... I have done alot of head gasket work in the past mainly to my dads Chevrolet's so I know how to replace one and know the signs of one I just thought that their might be someone else out there that knew of a back in the woods trick . Like the mexicans using egg yoke to quick fix a radiator enough to get them to the border
Old Jan 20, 2006 | 10:09 PM
78frd4evr's Avatar
78frd4evr
you know I bought this 88 bronco 2. the guy just put in a bunch of money in the upper end, and it blew a headgasket. he was tired of messing with it, and sold it to me for 800.00. If was blowing heavy white smoke driving it home, i left it setting in the driveway for 2 weeks, then was in walmart one day and picked up a bottle of prestone super sealer, and said what the hell im tearing it down anyway what will it hurt to put it in there? well I went on home started it up dumped it in the radiator. The white smoke stopped. this was in 1998 I drive it till 2001 with no trouble sold it to a kid , and now see it almost everyday running down the road. The guy flipped out when I told him how I fixed it and called me a lier. but this is a true fact that it did work, might have been once in 5,000 cars but the luck did happen. so now all my cars have a bottle put in them problems or not.
ppad1962
Nov 29, 2012 02:36 PM
DD1973
2009 - 2014 F150
Jun 17, 2012 10:01 PM
dscofever
Oct 30, 2007 09:47 PM
1982fordf100
Nov 11, 2004 11:25 PM
uphill50
1983 - 2012 Ranger & B-Series
Feb 4, 2004 08:32 PM
