turbo air guide from blackcloud info on it
I wanted to see if anyone had any info on the turbo air guide. My biggest issue is turbo noise. I like it driving around town but driving 3+ hours with the kids in the truck at 75mph the turbo noise starts to get to you. I have an early 99 model and the turbo noise is quite a bit louder then the 99.5-03.5. Im wondering if this really makes a noticeable difference in turbo noise. It looks like there are other benefits to using it as shown by the dyno results on blackclouddiesel.com. I really like the the torque numbers at around 2100rpms with about a 50ftlbs of torque increase. They did use a banks chip on both dyno tests with and without the tag installed. Any pros and cons on this would help. Thanks
http://www.blackclouddiesel.com/Ford/TAG/tag.htm
you could just put in a 99.5-03 turbo compressor wheel. defeating the purpose of curing turbo surge, but you will have a quieter turbo. all 10 blades are uniform height, not 5 short and 5 long. if you arent near 20 PSI much and don't suffer from stall, then this might be for you if all you are trying to do is hush the whine. i have my stock wheel on the shelf i could practically give you. PM me if youre interested.
I really dont want to open up the turbo and change anything out. I would probably screw something up. Plus I have the type of compressor wheel all the newer models are wanting to install. I rather just install something quickly to quiet it down a little bit. Going by the numbers on black cloud it looks like everyone would want one. I just would like to talk to someone that has used one and there opinions on it. I guess if all else fails I could buy it and try it. They do offer a 30 day money back guarantee.
[QUOTE=rosa70]I wanted to see if anyone had any info on the turbo air guide. My biggest issue is turbo noise. I like it driving around town but driving 3+ hours with the kids in the truck at 75mph the turbo noise starts to get to you. I have an early 99 model and the turbo noise is quite a bit louder then the 99.5-03.5. Im wondering if this really makes a noticeable difference in turbo noise. It looks like there are other benefits to using it as shown by the dyno results on blackclouddiesel.com. I really like the the torque numbers at around 2100rpms with about a 50ftlbs of torque increase. They did use a banks chip on both dyno tests with and without the tag installed. Any pros and cons on this would help. Thanks
http://www.blackclouddiesel.com/Ford/TAG/tag.htm[/QUOTE]
I have an '02 F-250 with the TAG and don't feel it quiets things too much...i love turbo sound in my truck! What i notice is quick spool up. Will be dyno testing the TAG's soon.
Nut
Nut
Originally Posted by Turbo_Whistler
Personally i doubt it will do or change anything. But there is a 30 day gauarantee i guess, for what its worth. Reminds me of that little tornado thing that came on the scene, looks good on paper but really doesn't make any difference.
Nut
