turbo air guide from blackcloud info on it
I wanted to see if anyone had any info on the turbo air guide. My biggest issue is turbo noise. I like it driving around town but driving 3+ hours with the kids in the truck at 75mph the turbo noise starts to get to you. I have an early 99 model and the turbo noise is quite a bit louder then the 99.5-03.5. Im wondering if this really makes a noticeable difference in turbo noise. It looks like there are other benefits to using it as shown by the dyno results on blackclouddiesel.com. I really like the the torque numbers at around 2100rpms with about a 50ftlbs of torque increase. They did use a banks chip on both dyno tests with and without the tag installed. Any pros and cons on this would help. Thanks
http://www.blackclouddiesel.com/Ford/TAG/tag.htm |
The link will not take you directly to it but once on there site hit the Ford truck link (of course) then on the left hand side under the ford heading hit the turbo stuff link. This will take you to it.
you could just put in a 99.5-03 turbo compressor wheel. defeating the purpose of curing turbo surge, but you will have a quieter turbo. all 10 blades are uniform height, not 5 short and 5 long. if you arent near 20 PSI much and don't suffer from stall, then this might be for you if all you are trying to do is hush the whine. i have my stock wheel on the shelf i could practically give you. PM me if youre interested.
I really dont want to open up the turbo and change anything out. I would probably screw something up. Plus I have the type of compressor wheel all the newer models are wanting to install. I rather just install something quickly to quiet it down a little bit. Going by the numbers on black cloud it looks like everyone would want one. I just would like to talk to someone that has used one and there opinions on it. I guess if all else fails I could buy it and try it. They do offer a 30 day money back guarantee.
[QUOTE=rosa70]I wanted to see if anyone had any info on the turbo air guide. My biggest issue is turbo noise. I like it driving around town but driving 3+ hours with the kids in the truck at 75mph the turbo noise starts to get to you. I have an early 99 model and the turbo noise is quite a bit louder then the 99.5-03.5. Im wondering if this really makes a noticeable difference in turbo noise. It looks like there are other benefits to using it as shown by the dyno results on blackclouddiesel.com. I really like the the torque numbers at around 2100rpms with about a 50ftlbs of torque increase. They did use a banks chip on both dyno tests with and without the tag installed. Any pros and cons on this would help. Thanks
http://www.blackclouddiesel.com/Ford/TAG/tag.htm[/QUOTE] I have an '02 F-250 with the TAG and don't feel it quiets things too much...i love turbo sound in my truck! What i notice is quick spool up. Will be dyno testing the TAG's soon. Nut |
Personally i doubt it will do or change anything. But there is a 30 day gauarantee i guess, for what its worth. Reminds me of that little tornado thing that came on the scene, looks good on paper but really doesn't make any difference.
Nut |
Go find a closed element filter box. Like the stock one....just a whole lot better. That will quiet things down significantly.
The AIS is good for that...but i can still hear my WW sing!
Nut |
I suggest a closed filter box as well, like the AIS.
