The injectors on my 95 300 have FOSE-B5A stamped on them. There is also a D above that number, but i don't think its important.
I have found these are bosch injectors, number 280150941, but i don't know what the flow rating is.
I know that Accel makes quite a few different flow rated injectors (probably just bosch, what isn't?) and i'd like to see if I could find something close.
Anyone know how to find out the flow rating of these things?
I've read that the stock injectors are 12lb, but also that they are 14lb. I know they run at a higher pressure, but is it 12lb injector at high pressure yielding 14 at the standard 3 bar, or is it 14lb yielding 17lb at the standard 3bar?
If the stock is 14lb/hr, what do you guys think about popping these guys in? I checked the chart and it doesn't appear that anything came with a 15lb/hr injector stock. So i guess the junkyard search is out of the question.
I'm going to wait untill i get back to school and use the scanner at work and see what the fuel trim level is at. My friend suggested this. That way i'll know how far out of whack the computer is.
