93 explorer odd braking
Old Jan 19, 2006 | 09:29 AM
VagrantFox's Avatar
VagrantFox
My 93 explorer XLT will sometimes while braking make this sound that somewhat resembles a fart (sorry that's the best i can describe it). It seems to do this especially when braking on ice. Any ideas what's up? or should i even be worried about it?
Old Jan 19, 2006 | 11:46 AM
Mudder's Avatar
Mudder
I think thats the samething thats happens to my 93,i think its just something with the ABS i havent had any problems with it other then it making that noise.
Old Jan 19, 2006 | 01:43 PM
marragtop's Avatar
marragtop
If you feel a pulsation in the brake pedal, then it's probably the ABS, which is what it's supposed to do.
Old Jan 20, 2006 | 01:43 PM
Jharger's Avatar
Jharger
Is it the same noise the ABS makes when you first start the car and drive a few feet? My 93 4W ABS has done this from day one. I guess it cycles the ABS piston. If this is the same noise then your ABS might be getting actuated when you hit the breaks. If it's not supposed to be doing this, ie tires are not slipping, first easy thing to check are the ABS sensors. Rear is located in the top of the diff, towards the front. Fronts are near the calipers and point to the rotors - kind of hard to see.
AC94EXPLORER
Dec 20, 2008 06:19 PM
jamidei
May 25, 2006 05:15 AM
crazyfoolreal
May 25, 2004 08:43 AM
93expleezee
Exhaust Systems
Jan 24, 2002 07:37 PM
winfordr
May 9, 2001 11:58 PM
