Do the 7.3 lifters ever fail?
Old Jan 18, 2006 | 09:49 PM
Highmark18's Avatar
Highmark18
Just trying to solve my problem per my previous post- the tick is more like a very small knock. Has anyone ever put in thicker oil to see if the noise goes away? I want to be pretty sure that is what it is before I dive into it-
Old Jan 19, 2006 | 01:11 AM
PLC7.3's Avatar
PLC7.3
You should have hung in on your last post as you were getting close to a pattern of things done.........
The fact that your tick is from the #7 cylinder area is disturbing, this is one of the cylinders prone to Cavitation. Are you loosing any coolant, you stated I believe, no excess smoke from the exhaust.
Yes lifters can fail, they are roller (wheel) type and can shatter the wheel, flat spot the wheel or just disintegrate the wheel assy. Usually you can see or measure a difference in height of the rocker assy. If lifters do break on occasion cam damage can occur, sorry to be so negative. You must diagnose the problem correctly, as disassembly is well into the bowels of the engine.
You say a knock, this could also be a bad injector, so loosen the cap nut for 15+ seconds on the #5 and then #7 injectors separately, closing of the #5 before opening the #7 then closing it. Did the knock go away at all, a definite loss of power and shudder should have been observed.
t_dickie
Sep 14, 2010 04:50 PM
mstiles19
Sep 22, 2009 11:45 PM
YungHotRod9090
17
Oct 4, 2006 12:48 PM
4ords4ever
New Member Introductions
Jan 28, 2005 12:09 AM
hreed
Dec 31, 2003 10:56 PM
