Steering column rebuild
Old Aug 25, 2001 | 09:08 AM
390fe's Avatar
390fe
Does anyone know if the u-joint in the tilt column of my '78 F150 is available as a replacement part from Ford?
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Aug 27, 2001 | 09:14 PM
oz9609's Avatar
oz9609
These don't normally wear out they just loosen up a bit. you can tighten them by the bolt & nut that goes through the joint. Tighten just enough to take out the slop any more will cause it to bind.
Old Aug 28, 2001 | 05:44 PM
390fe's Avatar
390fe
Thanks! Next time I've got it apart I'll try doing that.
Jason Kendrick
Old Sep 1, 2001 | 02:55 PM
390fe's Avatar
390fe
Phil, I was able to tighten the bolt just like you said and it's a whole lot better now! No play at all. Thanks again for the tip!
Jason Kendrick
Old Sep 1, 2001 | 05:21 PM
oz9609's Avatar
oz9609
Great Jason. Sure beats spending money, huh?
Old Sep 1, 2001 | 11:57 PM
390fe's Avatar
390fe
That's money that can be spent elsewhere on the '78!
Jason Kendrick
Old Sep 2, 2001 | 07:25 AM
NoPushrods's Avatar
NoPushrods
jason66
Dec 30, 2011 04:32 AM
390fe
Dec 31, 2006 03:03 PM
390fe
Sep 10, 2001 08:58 PM
390fe
All Things Towing
Jun 4, 2001 04:15 PM
390fe
Aerostar
May 13, 2001 02:17 AM
