Sponsored by: Kumho
89 Bronco
Old Jan 18, 2006 | 12:00 PM
LonnieD's Avatar
LonnieD
89 Bronco
I need to re-do sons brakes on his truck...are the front brakes just like any others? Take off wheel, compress the caliper, remove pads replace (turn rotors) pads and go...
Old Jan 18, 2006 | 01:20 PM
aurgathor's Avatar
aurgathor
Replacing the brake pads is easy, and it's just like any other, but taking off the rotor is a bit more complicated than usual because of the locking hubs.
Old Jan 18, 2006 | 04:11 PM
LonnieD's Avatar
LonnieD
hmm ok I'll try and look up the procedure..can the pads be replaced w/o removing the rotor? If I have too?
Old Jan 18, 2006 | 06:21 PM
aurgathor's Avatar
aurgathor
No, you don't need to do anything with the rotor if you just wan to replace the pads.
However, it's a good idea to inspect them, and do something if you see some major problems. I usually have them turned or replaced at every 2nd or 3rd set of pads.
Old Jan 19, 2006 | 05:00 PM
LonnieD's Avatar
LonnieD
Yeah I understand... I loked at Chilton and they show knocking out a pin a stuff..seems like a pain in the behand. So all I need to is remove the calipers and replace the pads no pressure to bleed or anything weird sense it's a 4 wheel drive
KarstenP
35
Aug 13, 2018 10:50 PM
tfdcapt
Aug 25, 2013 08:57 PM
mjlevi
Jan 15, 2007 09:52 AM
babock
2004 - 2008 F150
19
Sep 19, 2006 04:25 PM
Ryan50hrl
Garage & Workshop
Feb 23, 2002 04:50 PM
