Water In Headlight Lens?
Today I noticed that I have water accumulating in the passenger side headlight lens. I've looked everywhere I can see without removing the lens from the truck but I can't see how it's getting in there, no cracks or holes are visible. It's a 96 XLT. Anyone have any ideas?
Rob
Rob
I had the same problem a few times over the years. What I do if it has a plastic lens like the Broncos, is to just drill a small hole in the bottom front of the lens itself....or one in each corner vertically up from the bottom.....this will let the water drain and hopefully let enough air in to dry any moisture......hey it worked for me.
From my experience, drilling didn't help in removing water. Maybe I should have drilled it differently. Anyhow, I bought some new headlights not too long ago and they look amazing compared to the old yellowed,worn and torn chrome and moisture filled junk pieces i had. About 160 bucks or so including rediculous shipping charges for a pair of new headlights isn't so bad. Its way worth it.
Originally Posted by Encho
It´s better to replace it the way i see it, if some water enters through the holes you drilled (i know they´re pretty smal, but it´s still a posibility), it might damage the bulb.
I have a brand new set of lenses......the thing is it is such a PIA to remove and replace them, and the fact that since I drilled the hole in each lens the problem has not returned......well lets just say if I thought it was a better idea to replace them it would have been made so.
I'm going to drill it, what's the worst that could happen? It doesn't work and I have to buy a new lens, you never know unless you try.
Streetgang.... If yours are still working good I'd like to drill my holes in the same place you did. Where exactly did you drill them? Do you remember what size drill bit you used?
I drilled a hole in each corner of the lens. The water didn't just drain right out though, I had to blow some air in one hole and the water drained out the other. It took a couple days of driving for all the moisture to evaporate. Thanks again for the tip Streetgang, saved me a few bucks.
I had a Mustang that accumulated water in the headlight. I drilled three holes in the bottom, front part of the lense. I removed the light, drained all the water out, cleaned it real well, and siliconed anywhere there might have been a crack. After that, I got zero moisture in my headlights even after 2 years. Never had a problem with it blowing bulbs.
