Cold air intake???
Old Jan 17, 2006 | 04:31 PM
grizzley30814's Avatar
grizzley30814
Cold air intake???
Seem to remember a old post showing way to build a less restrictive air filter assembly for the 7.3. Can any one point me in the right direction. I think it used a k&n or napa filter and and just some 4inch hose or tubing.
thanks in advance
Old Jan 17, 2006 | 07:17 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's not really a cold air intake since it draws underhood air, but it most definitely flows way more than stock.
Try the search terms "tymar", "6637", or "kwikfilter"
Old Jan 17, 2006 | 07:30 PM
Brians97F250Crew's Avatar
Brians97F250Crew
Grizzley, you mean like this??
4" rubber coupler
4" 33 degree elbow
K&N universal filter ... K&N RD-1460
3 - clamps
Couple hours of my time.... oh and about $100
Old Jan 18, 2006 | 06:02 AM
grizzley30814
Thats it... thanks
Old Jan 18, 2006 | 01:19 PM
yukonsly's Avatar
yukonsly
Hey....does this setup actually increase airflow? What are the disadvantages to such a setup? I live in a pretty dry, dusty place. Should I stick to my stock box with a K&N filter in it? This seems to good to be true....so simple and yet what an improvement.
can you talk about that set-up a bit more.....really interested in this one.
Yukonsly
Old Jan 18, 2006 | 01:52 PM
Brians97F250Crew
If you have really dusty conditions I'd probably use the NAPA 6637 filter for peice of mind . It's larger in diameter but connects the same.
Old Jan 18, 2006 | 01:58 PM
Brians97F250Crew
None that I've noticed
I wouldn't. The stock box has had issues of letting air past the seal surface.
It's just a simpler setup. Got to love the sound of the turbo spooling up too.
Old Jan 18, 2006 | 05:47 PM
mjwhip2's Avatar
mjwhip2
If you are willing to spend the $100 to build one, you might as well just call Dale Isley (Tymar performance 509-922-8785) and get his. All of these "DIY" intakes are basically a copy of his, just not done quite as nice.
Old Jan 18, 2006 | 05:54 PM
yukonsly's Avatar
yukonsly
Will he ever have his website up? How much does his setup costs? if its like 300$ it's not worth it....to be honnest it's under the hood and out of sight....who cares what it looks like....my truck's not a show truck....
Yukonsly
Old Jan 18, 2006 | 06:04 PM
mjwhip2's Avatar
mjwhip2
About $150. Just give him a call. Make sure you have plenty of time to talk though. As anybody who has dealt with him knows, he likes to talk .
Old Jan 19, 2006 | 03:46 PM
1969fordguy's Avatar
1969fordguy
I wonder how much better a setup could look than BRIAN97F250CREW's? Good job man!
Old Jan 21, 2006 | 10:21 PM
Brians97F250Crew
1969fordguy..... Thanks for the compliment. One of these days I'm going to get the tube powder coated black. That'll make it look better yet.
Old Jan 21, 2006 | 10:48 PM
79f-250custom's Avatar
79f-250custom
Thanks alot Brians97F250Crew! thats exactly how i was going to build mine! now i have a pic to copy it from. now i just got to go to an abandond dairy farm and cut out some stainless steel milk pipe line out of the milkhouse free stuff man. and i cant belive you guys run K&N. there high flow and give power. but IMO they suck at filtering. ill stick with a bit more restrictive filter and have it filter better. but thats IMO.
and also... how did you bend your pipe? or did you buy it like that?
looking good!
Mitch
Old Jan 22, 2006 | 09:04 AM
Brians97F250Crew
Mitch .. .glad I could help you out. On the K&N's ... I've used them for years and years. Even rebuilt engines I've used them on exclusively and never saw any wear from dirt infiltration. But to each his own.
Stainless tubing for free!!! Can't beat that.
On the bent tubing .... I bought it that way. It's a 33deg bend exhaust elbow.
Old Jan 22, 2006 | 11:42 AM
79f-250custom
Well im going to get my supplies today. ill order up a K&N with the oils and the outter ware and ill c how she filters. ill have to bend that SS myself tho... or ill have to take it somewhere to have it bent.
thanks for the help. ill let you know how it goes.
Mitch
