Turbo a 92 idi?
Old Jan 17, 2006 | 01:53 PM
mackdog's Avatar
mackdog
Red face Turbo a 92 idi?
I ve got a 92 f 250 7.3 idi 5 spd 4x4 that I am interested in turbo charging. I ve heard a lot of guys talk about how they have successfuly turboed their trucks and have great power gains, especially when towing. I think it is a great idea and I am considering it , but the only concern I have is wether or not I will eventually blow a head gasket or intake gasket with the increased cylinder pressures. I know these engines have like a 22 to 1 compression ratio already, and am worried that I will over do it and hurt the engine. The truck has 215,000 miles on it. I think maybe im just worrying too much and I just need to turbo it and forget it. Maybe someone can clear things up. Also, I dont know which would be the best turbo kit for this truck, Banks or Hypermax?
Old Jan 17, 2006 | 02:32 PM
94_turbo's Avatar
94_turbo
or a ats--get the turbo--but--get pyro.boost,and trans temp gauges in at the same time-------------once turbo in--can turn up the pump 2 flats--then turn up boost--but on that engine--id stop at about 10 lbs of boost--some say 12--but not being a fac turbo engine-----------make sure if you buy the ats--get the larger housing for a three inch downpipe with it--no exhaust restrction--wont believe the diff it will make---also--keep the pyro below 1200 deg--or pistons start melting---not a good scenario--
Old Jan 17, 2006 | 08:54 PM
mackdog's Avatar
mackdog
Good point. The guages are probably key to runnin these trucks properly. How long have you had a turbo on yours? Or is it factory? Did the factory idi turbos make as big a differnce as the aftermarket ones do.? I drove a guys 93 f 250 with a factory turbo pullin a cargo trailer once and it seemed to make a big difference over my truck.
Is there an advantage to a wastegated setup as opposed to non wastegated?
Old Jan 17, 2006 | 09:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Get a wastegated ATS turbo.
It will run circles around the stock Ford turbo if you do the 3" exhaust with a see thru muffler or no muffler.
With the manual tranny you can skip the tranny temp gauge.
Do get a pyrometer and boost gauge though, install the pyrometer thermocouple in the stock exhaust manifold.
I am running ram air and an ATS turbo at 18 PSI on an 86 6.9 engine for boost.
3" exhaust, no muffler and dual 3" stacks, runs good.
Old Jan 17, 2006 | 10:38 PM
Highmark18's Avatar
Highmark18
I installed the ATS wastegate on my 92.
Like Dave said, you will not be dissapointed. The difference is nothing short of AMAZING!
Old Jan 18, 2006 | 10:47 AM
mackdog's Avatar
mackdog
Smile
What is the best way to buy one of those turbo kits, over the internet like on fleabay, or should I find a company rep somewhere here in ohio. Im not sure if finding a used setup would be the best idea, but I know it would be ALOT cheaper.
Old Jan 18, 2006 | 02:32 PM
Chevy_Eater's Avatar
Chevy_Eater
Keep an eye on ebay, broken ones with missing parts show up all the time with really bloated prices!
Red23
Dec 16, 2013 03:57 PM
40dog
Jun 17, 2012 08:41 PM
pontichev
Feb 10, 2009 07:06 PM
idifamilycab
May 20, 2007 08:03 AM
92f25073idi
Apr 29, 2006 09:31 PM
