Please Help Me Please!!!!!!!
Old Jan 16, 2006 | 07:09 PM
agg_bagg's Avatar
agg_bagg
Question Please Help Me Please!!!!!!!
Ok heres the problem. About a month ago my truck just died while driving down the road. I took it to the dealer and they looked at it and found out that my fuse for my ecu or something like that was burned out(it was the #30 fuse under the dash and it had a 30 amp fuse in it). They replaced it and it ran fine. They said that my aftermarket chip that is in there might be the problem cause he said that he couldn't find any other shorts. Well it did the same thing to me today and i replaced the fuse and now it runs fine again. I would like to know how to take the chip out, cause i've here that if you do it wrong it can mess up you computer. Any other info that you have about my problem would be great to. Thanks in advance
Jeron.
Old Jan 16, 2006 | 07:14 PM
lancer's Avatar
lancer
I know that the fuel heaters can short out sometimes blowing the ecm fuse. I'm sure someone will come to your rescue!! This is a great site!!
Old Jan 16, 2006 | 07:58 PM
Kwikkordead's Avatar
Kwikkordead
Unplug the electrical plug on the bottom rear of the fuel filter housing. That will disconnect the fuel heater until you can get it fixed. Your water in fuel sensor will be disconnected as well when you do that.
Old Jan 16, 2006 | 08:14 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If the cover has been modified so that you can access the chip without removing the PCM, then all you have to do is make sure the key is not in the ignition.
If you have to remove the PCM there's not really any danger. Disconnect the batteries, remove the PCM, remove the cover, remove the chip.
Old Jan 16, 2006 | 08:38 PM
agg_bagg's Avatar
agg_bagg
So if you guys had to guess what do you think is causing that fuse to blow. The fuel heater, the chip, or even something else?
Old Jan 16, 2006 | 08:52 PM
cookie88's Avatar
cookie88
FTE Emeritus
I doubt it's the chip. I would try unplugging the fuel heater first.
Old Jan 16, 2006 | 09:04 PM
agg_bagg's Avatar
agg_bagg
ok sweet thank you guys so much ill try that and hopefuly it gets the job done
Old Jan 17, 2006 | 07:11 AM
99F-250lova's Avatar
99F-250lova
My truck shut off out of no where the other week also. I had no clue why it shut off, but after that I just turned it back on and have not had another problem with it. Any takers?
Old Jan 17, 2006 | 08:26 AM
444in.ofgoodness's Avatar
444in.ofgoodness
Probably your CPS there, Lova. Check the thread on the IH 'blue' CPS. The camshaft position sensor is one of those things that's guaranteed to go sooner or later on these engines. If yours is OE, or hasn't been done in a while, that'd be the first place I'd look. Also, check for DTCs - a faulty CPS will usually throw a code, but won't necessarily light up the check engine light, especially if it's an intermittent problem.
Old Jan 17, 2006 | 12:00 PM
99F-250lova
Thank you for the help goodness! I will check it out as soon as possible.
