1998 expedition - worth it?
Old Jan 16, 2006 | 04:23 PM
idoxlr8's Avatar
idoxlr8
I came across a 98 expedition - flawless, garage kept, xlt model, not a scratch or dent on it. Interior same as the exterior - flawless. Took it for a 50 mile test drive - perfect. New tires, shocks, brakes, new exhaust.
However, it has 204,000 miles on her. Engine so clean you could eat off it.
$5000.00 but my concern is the mileage --- comments???
Old Jan 16, 2006 | 04:45 PM
Phil056's Avatar
Phil056
I have 150,000 or so miles on mine 98 XLT and it doesn't drop a bit of oil. If they just put on tires, shocks, brakes and exhaust you are looking at $1000 right there alone. I would think 5k is worth it, just my 2 cents.
Good luck
Old Jan 16, 2006 | 04:47 PM
ford390gashog's Avatar
ford390gashog
204k on the engine is really not a lot. what engine 5.4 or 4.6???
Old Jan 16, 2006 | 04:52 PM
idoxlr8's Avatar
idoxlr8
Sorry forgot to mention it's the 5.4
Old Jan 16, 2006 | 04:54 PM
ford390gashog
we see plenty of 5.4's that are abused go 250-350k miles. few people here with 375k on them.
Old Jan 16, 2006 | 07:55 PM
98expeditionXLT's Avatar
98expeditionXLT
How does the engine sound on cold start-up and after a few minutes?
Old Jan 17, 2006 | 03:53 PM
idoxlr8's Avatar
idoxlr8
I'm going to drive it again weds. I'll pay attention to the cold start-up. I didn't know what to observed the first time because I'm a Jeep guy. I'll ask if any of the coil packs have been replaced, and look at the bottom of the doors for rust. Now you all have alerted me to the piston slap. I love the forums - you learn so much.
I do need to get back with guy. He says he's documented the entire history of this vehicle. I still can't believe how clean this expedition is.
Old Jan 17, 2006 | 05:46 PM
alwaysready's Avatar
alwaysready
ya my f-250 has a 5.4 with slight piston slap when its cold i drive 5 blocks and its gone. talked to a ford tech he said there is a tsb about it and it in no way is any signs of anything going bad. i have 130,000 on it.
Old Jan 19, 2006 | 10:08 AM
natsoundup's Avatar
natsoundup
my 98 expedition has 145k miles...it burns a quart of oil every 1500 miles.
the only things that have gone wrong with it are a blown sub (teenager), and turn signal stalk issue... i have replaced the front rotors once, shocks, idle air control valve (now clean it instead of replacing), and oil changes every 3k miles. antifreeze every 2 years. one front end alignment. the cd player jambed once...but my teeanger fixed it. I also change the tranny fluid and power steering fluid every 30k. I am on my third fuel filter as well. I do all the work myself (except alignment and rear shocks)
it is the only new vehicle i have ever purchased...guess i can't complain. i figure i will do one transmission rebuild and see how many miles i get out of the engine. i'll be happy with 225k.
I would just be concerned with a tight front end at that mileage...maybe some new sway bar bushings and shocks would be i order...
Old Jan 19, 2006 | 01:47 PM
Phil056's Avatar
Phil056
natsoundup,
How did the turn stalk installation go? I need to do that on my '98 soon (washer pump has no juice going to it).
Thanks...
Old Jan 19, 2006 | 01:57 PM
98expeditionXLT
Phil056,
Check with your Ford dealer as I think there was a recall on the 98 Exp for the multifunction switch several years ago.
Old Jan 19, 2006 | 02:59 PM
natsoundup's Avatar
natsoundup
my stalk was fixed under warranty.... i don't think it would be difficult to do ...I have the paper manuals and should be able to look it up for you and report back...
i can't remember what the issue with it was..it was awhile back...
don't remember a re-call... we are under some sort of recall now...but I haven't had the time to go take it in...
Old Jan 20, 2006 | 08:11 AM
Phil056's Avatar
Phil056
Originally Posted by 98expeditionXLT
Phil056,
Interesting.....
Thanks for the heads-up will look into it today.
Thanks!!!
Old Jan 21, 2006 | 03:01 AM
MisterCMK's Avatar
MisterCMK
I don't blame you on that one. The drivers side rear shock sucks to replace on those trucks.
Old Jan 21, 2006 | 06:02 PM
shadows4's Avatar
shadows4
Thumbs up
I have two Expediton's. A 98 with 210,000 and a 01 with 198,000. Outside of tires shocks, and brakes, I replaced an alternator and #4 coil pack on the 98 and just plugs on the 01. $5k sounds like a good price to me.
