door ajar sensor...
Old Jan 16, 2006 | 09:53 AM
buckshot047's Avatar
buckshot047
door ajar sensor...
anyone know how to tell which one is sticking and indicating and open door? Also how do you actually get to it to replace?
Thanks
Old Jan 16, 2006 | 12:56 PM
pclark76's Avatar
pclark76
I had a mechanic friend tell me where it was. Inside the door, next to the latch. Could not get my arm to it so i just cut the wire, no more annoying dinging. But have to be careful about leaving lights on. Both of mine were out.
Old Jan 16, 2006 | 02:47 PM
99F-250lova's Avatar
99F-250lova
What wire do you cut? I am having the same problem and it starts to get on my nerves after a while.
Old Jan 16, 2006 | 04:48 PM
pclark76's Avatar
pclark76
My truck is an early 99 XL - no power nothing. The door ajar sensor wires were the only wires in the door. They (2 - I do not remember what color) were run along the bottom under the window glass then up to the sensor. Slipped off the door cover, cut and taped the end of the wires. But I learned the hard way to check if the lights were on. Came out one day to go to work and nothing. Had left lights on and with the sensor wires cut, the truck thinks the door never opens so no beep with lights left on.
CAT_man_963's Avatar
CAT_man_963
Try spraying WD-40 in there all around the door latch - a lot of times that will fix up your sticking switch!!
Old Jan 16, 2006 | 06:26 PM
cangim's Avatar
cangim
Don't know your cab configuration, but it is usually the driver door as it is used the most. The switches themselves are not that hard to change out, remove two screws from the door panel, located behind relflector and under the switch panel on door, lift panel off, remove the three torx screws off the latch, followed by disconnecting electical to the solenoid and switch. the switch simply twists out.
Old Jan 16, 2006 | 09:03 PM
44990875's Avatar
44990875
yep... the door latch, where it hits the striker post is seized. Ford trucks are notorious for this .
spray a little PB blaster from AutoZone on the door side of the mechanism. Let it sit overnight, and spray with a good lubricant and your problems will go away.
I have 3 F350 crewcabs and the rear doors are know for this issue.
Old Jan 16, 2006 | 09:58 PM
00250diesel's Avatar
00250diesel
i just unplugged mine. i didnt want to cut the wires so later on when i decide to replace it i can. thw wd 40 didnt work for me
Old Jan 17, 2006 | 02:24 AM
StrokedRanchero's Avatar
StrokedRanchero
I replaced my drivers door switch last year, about $17- $19 from the dealer, part #XF1Z.10B987.AA or XF1Z.14018.BA. It took about an hour. Now I think my rear door driversside switch is going bad. I am going to spray WD or PB on it and hope that does it. I tried it on the driver's door and it work for about 6mo. then went out all together.
Old Jan 17, 2006 | 03:11 AM
99F-250lova
So most likely it is my driverside door that is going bad? I guess I will try some WD-40.
Old Jan 17, 2006 | 03:59 AM
cangim's Avatar
cangim
That is where I would start, but if you are doing WD why not do a little preventative and do all, just the way I look at it.
Old Jan 17, 2006 | 06:55 AM
99F-250lova
Sounds like a good idea cangim!
Old Jan 17, 2006 | 08:12 PM
molotov's Avatar
molotov
I hate cutting wires. Had the same problem, soaked it with wd-40, and problem solved. If I could have only used that on my Ex.
nuknuk
Aug 22, 2016 04:55 PM
tallac19
Jul 1, 2012 02:10 PM
ZFamly
Jan 29, 2011 11:20 AM
jefxxo
Jul 28, 2009 09:46 PM
T T 1
Paint & Bodywork
Aug 11, 2002 09:44 PM
