General Automotive Discussion
Taurus tranny interlock
Old Jan 16, 2006 | 09:52 AM
rikfish's Avatar
rikfish
I am looking for any hints as to what to look for with my dad's Taurus. Seems it will start, but you cannot get it out of park. I am going over to his house in a few minutes to look at it. Is their a fuse that controls the transmission safety interlock for the brake pedal? Any help will be appreciated.
Old Jan 16, 2006 | 12:21 PM
Fordzlla's Avatar
Fordzlla
From my Hayes manual (96-'01 taurus)
To diasble the shift lock system
- if the shifter is locked in the park position, even with the brake pedal depressed, apply the parking brake, turn the ignition key to LOCK, then remove the key.
-Insert the key and turn it to OFF. Press tyhe brake pedal
-Shift to Neutral, start the vehicle and select the desired gear.
Is he using a new key? It could be the anti- theft system kicking in.
Old Jan 16, 2006 | 01:31 PM
Ford_Six's Avatar
Ford_Six
The brake switch may be bad, check to see if the brake lights are working.
Old Jan 16, 2006 | 04:41 PM
rikfish's Avatar
rikfish
OK, first off, I want to thank both Ford Six and Fordzlla for their help.
I found the problem pretty quickly this morning. I had an idea it might be the brake light switch, or thought their might be a seperate switch for the interlock. As I removed two pin connector one of the wires popped off to the side! It had broken right at the crimp on the connector. As a note, I did check the brake lights, but they seemed to be working ok. The problem here was my 82 year old dad was watching the lights for me, and they were intermittent due to the broken wire! ( found this out later when he told me they had flickered but he thought I was just tapping the pedal.)
I simply resoldered the wire for a temporary fix. I broke the side out of the connector to get to the lug to solder the wire, so I went to a salvage yard and for a buck got another connect with about 3 inches of wire as pigtail which I will splice into the original harness.
Again, thanks for the quick responses. This is exactly why I stick around this board! I have offered my help a few times, but have received 100 fold help in return.
Old Jan 16, 2006 | 07:34 PM
rikfish's Avatar
rikfish
First off, I want to thank Fordzlla and Ford_6 for their help. This is why I stick around this board! The FTE community is absolutely unbeatable.
I did find the problem fairly fast this morning. Jared,you were close. I had checked the brake lights and "thought" they were working. I had my dad in back watching and he told me they were working. I did suspect something at this point as he seemed a little off as he reported yes/no as I pushed the pedal. As I was removing the wiring connector to the switch, one of the wires just popped to the side. I figured this was the problem, but went ahead and checked the switch anyway.
Apparently the wire that had broken was making intermittent contact and made it appear the lights were working. I had to break the side of the connector out so I could solder the wire back onto the lug. Works as advertised now. I consider this a temp fix and have made the trip to the salvage yard and bought a connector with about 4 inches of wire and will butt-splice it in soon.
Again, thanks for the help. Long Live FTE!!!!
Old Jan 16, 2006 | 08:03 PM
bosshoss's Avatar
bosshoss
I think there is a recall for this problem, check with your Ford Dealership.
Dave P.
Old Jan 16, 2006 | 09:01 PM
rikfish's Avatar
rikfish
Dave,
I searched the recall area here on FTE, found only 2 recalls listed, neither related to this problem. I will however look into this further. I'm not too concerned since I have a "new" used connector to splice in, and I doubt it will give any more problems. I plan on stress relieving this part of the harness to minimize any movement of the wire near the connector. This should eliminate the broken wire. I suspect the break was caused by the wire flexing every time the brake pedal was used, probably breaking due to it being nicked when the insulation was stripped. The break occured right at the point of the crimp of the spade lug. My best guess of course......
Old Jan 16, 2006 | 10:40 PM
bosshoss's Avatar
bosshoss
I wish i still had the info, my Taurus had the brake light switch repaired by ford. I will try to dig up something. Good luck.
Dave P
Old Jan 17, 2006 | 12:29 AM
Racerguy's Avatar
Racerguy
The recall on the brake light switch was for 2000 and 2001 Tauruses with power adjustable pedals.
Old Jan 17, 2006 | 07:41 AM
rikfish's Avatar
rikfish
Thaks for the info Dave!
Upnorthfro
Apr 9, 2012 12:17 PM
msm20032003
Crossovers
Jun 8, 2009 09:35 PM
DansF350
Electrical Systems/Wiring
Jul 2, 2005 04:18 PM
parrothead_tpa
1997 - 2003 F150
Apr 8, 2004 12:18 PM
