302 questions
Old Jan 11, 2006 | 01:34 PM
wakojoe's Avatar
wakojoe
Question Whats my power gain
I'm planning to swap a 93 HO into my 87 F150. What will be my gain going to the newer HO heads with the truck cam & intake?
Old Jan 11, 2006 | 02:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper engine specific forum.
Old Jan 11, 2006 | 03:02 PM
bob1987f's Avatar
bob1987f
i might be wrong but ive heard that the heads are the same. just the cam intakes and computer are more agressive on the HO.the truck has 185hp stock, and 225 on the HO, my guess is that you would be somewhere in the middle
Old Jan 11, 2006 | 03:11 PM
ken75ranger's Avatar
ken75ranger
I'd be suprised if there is any difference.
Old Jan 11, 2006 | 04:10 PM
EPNCSU2006's Avatar
EPNCSU2006
The heads are the same to the best of my knowledge...both are E7TE's. The cam is really where the power difference is, so if you change it back to the truck cam, you are not going to gain anything at all. Well maybe a little if the HO compression ratio is any higher than the truck engine.
Old Jan 11, 2006 | 04:27 PM
Kemicalburns's Avatar
Kemicalburns
there will be no change at all. you want change swap in a 5.8
Old Jan 11, 2006 | 08:33 PM
wakojoe's Avatar
wakojoe
I want to put the mass air in soon after I get it up and running, along with a K&N and full exhaust aswell. It will be a offroaded some but mostly just personal use. I want something with a healthy note but with good street manors. What cam do you guys recommend?
I will be leaving the truck intake on it.
Old Jan 11, 2006 | 09:35 PM
MustangGT221's Avatar
MustangGT221
It definitely has the same E7TE heads on it. The differences between a mustang HO 302 and a truck 302...are headers vs manifolds, short runner vs long runner intake manifold, different cam, different firing order, MAF SEFI vs SD EFI, and single 65mm TB vs dual 45mm TB.
The mustang would be at 225hp and the 87 truck at 185. The 94ish trucks moved up to 205hp from 185.
Old Jan 12, 2006 | 09:39 AM
wakojoe's Avatar
wakojoe
Would it be a dumb idea to use all the HO stuff in a truck? How do you think it would run with the HO cam an SD until I can put the mass air in?
Old Jan 12, 2006 | 10:45 AM
Kemicalburns
i hear that cam works well in a truck if you install 1.7 rockers but dont quote me on that. if you go mass air your cam choices increase a lot. but if you continue to run SD then call compcam and see what they recommend. I beleive that motor will be setup for a roller cam as well so be sure you mention that to them.
Old Jan 12, 2006 | 12:23 PM
wakojoe's Avatar
wakojoe
1.7's and the HO cam with SD? I was thinking that the idle would serge, or is that the cam that comes in SD Mustangs? Can I use the Mustang intake also? The engine I have didn't come with lifters, pushrods, or rockers can I use the ones out of my truck with the HO cam or do they need to break in together?
Thanks
Old Jan 12, 2006 | 03:54 PM
MustangGT221
You could use the mustang intake and throttle body but I'd recommend just using the truck stuff. It'll help get you a better low/mid range torque level which is important with the dinky 302 in a truck.
The HO cam would work, but do ya really wanna switch it when you run MAF? It'll be a heck of a lot easier to do all of this at once. Put that setup together and run it off MAF with a comp cam and 1.6 rockers. See if you can pick up a roller tip rocker as they're better and not that much more money (don't have to be the fancy aluminum ones).
Old Jan 15, 2006 | 03:32 PM
wakojoe's Avatar
wakojoe
Question 302 questions
Just some last minute questions....
Can I use the lifters, pushrods and rockers out my 87 F150 5.0 in a 93 HO with the stock HO (used) cam and heads? If not what is a good set to buy if you are doing a buget build?
My truck is a stick and the donar car was an auto, will I need a new balancer?
Im also putting mass air in any tips where to buy the wiring and comp?
Thanks, Joe
Old Jan 16, 2006 | 12:11 PM
wakojoe's Avatar
wakojoe
Thanks for any help.....
Old Jan 16, 2006 | 03:07 PM
ken75ranger
Thanks, Joe
I don't thiink so on the truck lifters you need roller lifters for a '93 ho cam.
Balancer should be good.
Can't help you on the wiring
