Offroad & 4x4
Dual Battery Set-ups
Old Jan 14, 2006 | 07:41 PM
ramboss429's Avatar
ramboss429
I'm going to be adding a dual battery setup in my '67 Ford. Can any of you guys post up pics of your setups, and where is the best place to buy good quality battery cables in 6ft lengths or so? Around here its impossible to find.
Old Jan 14, 2006 | 08:06 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
are you running them hooked together or you running an isolator?
Old Jan 14, 2006 | 08:16 PM
7FORD2's Avatar
7FORD2
i to am interested in dual battery setups.
Old Jan 14, 2006 | 08:40 PM
oldhalftons's Avatar
oldhalftons
It's best to run an isolator. Most isolators will charge both batteries at the same time and only pull power from the second battery when the engine isn't running. Some will let you swap which battery is the starting and which one is the AUX by flipping a switch.
Old Jan 14, 2006 | 08:55 PM
surewhynot's Avatar
surewhynot
I get my battery cables from Napa. Thats the only place I've found the heavy cables in any kind of long length. I'll put some pics up tomorrow. I'm also running an isolator.
Old Jan 14, 2006 | 09:02 PM
Bouts21's Avatar
Bouts21
Two batterys in mine, positive of the main battery to an isolator, then on to the positive of the secondary, Grounds to grounds. I bought #2 welding wire, and new connectors, works great and looks good. Moimted the second battery in the same spot as the main battery, but on the driver's side of the truck
Old Jan 14, 2006 | 09:14 PM
chrono4's Avatar
chrono4
plan on going with duals when i get my 88 put back together, where did yall get your isolators?
Old Jan 14, 2006 | 09:42 PM
surewhynot's Avatar
surewhynot
I ordered my isolator from Summit. Can't remember how much it cost though.
Old Jan 14, 2006 | 10:49 PM
RawPower's Avatar
RawPower
You may have this already solved, but for mounting them you could go to a junkyard and get the batt tray of a diesel... or maybe just a stock one but flipped around would work too. but yall probably thought about that
Old Jan 14, 2006 | 10:50 PM
ramboss429's Avatar
ramboss429
I was plannin on just running them together. Wasn't aware of needing an isolator.
Old Jan 14, 2006 | 10:56 PM
ramboss429's Avatar
ramboss429
I was just planning on making my battery trays out of angle iron, nothing too fancy, just functional. I could always chrome 'em out for the bling bling factor
Old Jan 14, 2006 | 11:06 PM
oldhalftons
you can, but if there is a problem the weak battery will discharge the good battery.
Old Jan 14, 2006 | 11:11 PM
ramboss429's Avatar
ramboss429
I went an did some reading in Isolators, they don't give those things away. So a guy could just get by running dual batteries without one. I was planning on running dual batteries to run my off-road lights and a winch in the future.
Old Jan 14, 2006 | 11:20 PM
RubberDuck's Avatar
RubberDuck
I run dual batteries in my bogger, without an isolator. They were both new batteries and have had no problems at all with them for over 2 years now.
RubberDuck
Old Jan 14, 2006 | 11:22 PM
oldhalftons
If you wanted to go cheap, cable them together in parallel, and use a blade switch to disconnect one battery when you need to use the winch or stuff when the engine is off, that way you'd have a fresh battery to start the truck with. when your running the engine use them both. basicly its an isolator, but your doing it manually.
the problem running 2 batteries is that everytime I get out of the truck in the rain, someone just has to tell me. "your lights are on".
I know they are on, I just don't care. I'm pumping gas, it will be running in 2 minutes. even one battery would be fine
