Its has ended
Old Jan 13, 2006 | 09:28 PM
puffer's Avatar
puffer
Smile Its has ended
last night i replaced the oil temp sensor and installed the ihp crossover oil pipe. hoping that the oil temp sensor was the smoking problem, but no luck still puffing away. so went in the house with my head down from being defeated again with the smoking problem so i decided to watch some tv. then decided to search this forum and hoping that i would find answer seaching and reading away and came across the thread about the cps and reading on how it controls timing, so i thought about it and said if it controls timing that means the pcm would add more fuel, that being said i changed the cps sensor and holy sh#% it stopped smoking and idles perfect like a champ drove it all day and nothing. smooth driving and better power band. the best thing was last night when i was installing the oil temp sensor looking in the engine valley there was a briight pink sticker that jumped out in my face and i read it. it said remain oil injection pump and then i was looking harder and saw the fuel pump was shiney and new looking. (bonus) I like to thank the supporters of this forum for all the help you all are a big help thanks
Old Jan 14, 2006 | 06:50 AM
jimkidd's Avatar
jimkidd
Thumbs up
That's just the kind of story I like to hear.
Old Jan 14, 2006 | 08:22 AM
F350_Hauler's Avatar
F350_Hauler
I have heard that it's a good idea to keep a crank position sensor in your glove box. They are cheap(how much?), They are easy to install(tell us more, Puffer) and they are a common cause of dead-on-the-road breakdowns. Just my $.02.
Old Jan 14, 2006 | 10:19 AM
puffer's Avatar
puffer
the cps goes for about $120.00 and it takes a 10mm wrench and a little pry bar to nudge it out (if its been in there a while). i still cant beleive that all my problems were from a dam cps sensor. if anyone has this problem try this sensor first.
Old Jan 14, 2006 | 11:30 AM
barebackjake's Avatar
barebackjake
your one of the rare ones that has had one of the bad running problems instead of the typical dead in the water failure. good to hear you got it.
Old Jan 14, 2006 | 01:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Like Jake said....The vast majority of the time a bad CMP sensor will just make it die. That's great work figuring it out, I'm glad you got her running right finally.
Cool finding the new parts on there too.
Old Jan 14, 2006 | 01:36 PM
puffer's Avatar
puffer
thanks guys this forum is great
Kowdog
Jan 10, 2014 10:34 AM
carrcreekcaller
Jan 16, 2012 05:13 PM
BILL.B
Aug 12, 2011 07:31 PM
nateairman
39
Nov 8, 2009 10:02 AM
UglyTruck
Jul 25, 2004 02:12 PM
