Lift ?
Old Sep 13, 2001 | 03:20 PM
AaronW's Avatar
AaronW
Lift ?
I am thinking about putting a 3" body lift on my 77 4X4. It already has 3" block lift between the rear leafs and the axle and I am planning on putting some heftier springs under the front end to get it to sit up better. How hard is it to do a body lift? I mess around with me truck all the time and I am a decent mechanic. Tons of time and plenty of help. What kind of tools, time req, stuff like that.
Thanks
Aaron
Old Sep 13, 2001 | 06:53 PM
fordmanSLO's Avatar
fordmanSLO
Lift ?
Well, from my experience, its not that hard if you take it slow, and plan for everything. You're definitely gonna need a floor jackor hi-lift or something, to lift the body off the chassis. Just stick some boards and a cloth in between so you don't hurt the body. Unless your kit requires welding(which most dont) then its pretty easy to do with basic tools. Let me know if you need anything else
Old Sep 14, 2001 | 04:40 AM
NoPushrods's Avatar
NoPushrods
Lift ?
Pardon my ignorance but what do you do about your existing body mounts when installing a body lift? Do the lift blocks go on top of the existing or do they replace them entirely? I've never installed one but am about to soon.
Thanks
Old Sep 14, 2001 | 08:53 PM
fordmanSLO's Avatar
fordmanSLO
Lift ?
the original ones are usually left in place, the new ones are just stacked on and bolted through the old ones.
Old Sep 18, 2001 | 01:11 PM
kjett's Avatar
kjett
Lift ?
Since the original bushings are really old, it would be a good idea to change out to urethane bushings while you are instaling the body lift. Plus the urethane usually sits a little (about 1/2") higher than factory or replacement rubber bushings.
Karl Jett
'95 F-150 ext cab Eddie Bauer F-150 4x4
slightly worked 351, E4OD, Pro Comp MT 33's
350 hp at the rear wheel (I said slightly worked!!)
Old Sep 19, 2001 | 12:38 PM
AaronW's Avatar
AaronW
Lift ?
Thanks for the info, where/who has good urethane mounts? What about throttle linkage, radiator hoses, etc. Will those be affected by raising the body?
Thanks
Aaron
Old Sep 19, 2001 | 01:55 PM
kjett's Avatar
kjett
Lift ?
You can try either JC Whitney or 4Wheel Parts Wholesalers for hte urethane bushings as well as the body lift. As for the throttle linkage, radiator hoses and such, well I've never had a problem, but you really want to check things over good to make sure you have enough slack.
Karl Jett
Old Sep 19, 2001 | 03:55 PM
Kenny's Avatar
Kenny
Lift ?
[font size="1" color="#FF0000"]LAST EDITED ON 19-Sep-01 AT 04:56 PM (EST)[/font][p]Hi, Two things I encountered were losing 3" on the 4WD shift lever, and the bumpers being 3" too low. I don't know what kind of kit you have, but if those things aren't included (mine wasn't) they can be fixed pretty easy. For the front bumper, I made spacers for the top bolts (to fit between the bumper and frame), and I drilled new holes 3" higher for the bottom holes. For the rear bumper, I just lifted it and drilled new holes in the frame. For the 4WD shift lever, I just made a 3" extension piece.
Kenny
Old Sep 19, 2001 | 08:44 PM
jowilker's Avatar
jowilker
Lift ?
fordman67
Aug 19, 2012 09:41 PM
av226
13
Jun 21, 2010 11:28 PM
AaronOregon
Jul 30, 2009 10:27 AM
CMPNS8
Jan 27, 2008 11:45 AM
