Stuck float
Old Jan 13, 2006 | 07:57 PM
rmalottwtes30's Avatar
rmalottwtes30
Stuck float
I have a new carb, and a real rusty gas tank, today it was running and started pouring gas out the carb, we knew it was a stuck float, we took the carb apart and the thing was loaded with rust deposits, the fuel filter didnt pick the crap up, so would rust being in it cause the float to stick. Anyways 120 bucks later I have a new gas tank, first off I am going to run all new gas line. Thanks for any and all help guys!!
Old Jan 13, 2006 | 08:09 PM
79 F-150 Stone's Avatar
79 F-150 Stone
I had a similar problem after getting new gas tank. A peice of rust stuck the needle open. I was on the road at that! I switched to the other tank, banged on the side of the carb and eventually it celared.
I installed a new electric fuel pump, with a filter at the pump and two in line filters at the carb in case the first one plugged up I could simply take it out and bypass it on the fly. I replaced all filters after two tanks of gas and all has been good since.
Old Jan 13, 2006 | 10:26 PM
Mil1ion's Avatar
Mil1ion
I put an in-line fuel filter between the tank & carb to pick up the big pieces of tank debris, it gets changed out once a year.
Old Jan 13, 2006 | 10:27 PM
ford390gashog's Avatar
ford390gashog
you need to add a inline clear filter on the frame somewhere.
wmcewan
17
May 7, 2017 12:58 PM
GreenMtnMan
Apr 24, 2017 08:58 AM
ghostshark
17
Sep 18, 2016 01:23 AM
nollaig
46
Jan 2, 2013 10:24 AM
logan.hawes
Sep 19, 2011 01:03 PM
