occasional problem with starting
Old Jan 13, 2006 | 06:46 PM
xTritonV10x's Avatar
xTritonV10x
Hey everyone, recently, my 1990 f350 has had trouble starting on occasion, what usually happens is that it will start normal most of the time, but occasionally, when I trun the key it sounds like the battery is dead, I'll try turning it again and it is usally successful, but sometimes takes a few tries. Does anyone have an idea of what the problem is? Thanks in advance.
Old Jan 13, 2006 | 07:18 PM
Popa Tim's Avatar
Popa Tim
Check your battery cables and connections. replace the cables if you see any corrosion and clean up any on the connectors. Check the frame to block ground cable also.
deronsaylor
1997 - 2003 F150
Jun 14, 2010 12:12 PM
wsckrb
Jan 13, 2005 08:03 AM
the handyman
Jan 10, 2004 07:13 AM
shomby
Nov 17, 2001 04:09 PM
