Whats the difference?
Old Jan 13, 2006 | 02:52 AM
racoonbandit's Avatar
racoonbandit
Just got a question about positive grounds. What is the difference between having a negative ground and a positive ground. My 54 has a neg. ground(12v),but a buddy of mine has a 54 packard with pos ground (6v). I asked him what the diff was and he wasn't sure.
Thanks,
Matt
Old Jan 13, 2006 | 06:31 AM
mtflat's Avatar
mtflat
Simple answer? On positive ground systems the positive battery cable is connected to the frame/block etc and the negative cable runs to the starter/ignition/coil etc.
Negative system is the opposite. (-) cable to frame/block and (+) cable to starter/ignition/coil
Both work fine.
Old Jan 13, 2006 | 01:13 PM
AXracer's Avatar
AXracer
Well actually your 54 came from the factory 6V + ground Ford didn't start using 12V - grd until 56.
Old Jan 13, 2006 | 07:32 PM
286merc's Avatar
286merc
Positive ground is actually the better way since it follows true electron flow. Ever notice that you dont get that battery post crud with + gnd?
However with the advent of higher output electrical systems and 12V some genius committee decided to standardize on negative gnd. A few years later this became a good idea as solid state devices are primarily PNP designs which work off negative grounds, otherwise the radio would require being isolated from the chassis, etc.
Old Jan 13, 2006 | 11:48 PM
racoonbandit
Easier of an answer then I thought it would be. Thanks for the input.
Matt
Old Jan 13, 2006 | 11:51 PM
Brian_B's Avatar
Brian_B
So...mine (56) is actually factory that way? I was not sure. Thanks AX.
Old Jan 14, 2006 | 11:02 AM
Earl's Avatar
Earl
Brian, if you have a 12V negative ground then it's the stock setup. Trucks before 1956 used the 6V positive ground system.
Old Jan 14, 2006 | 09:32 PM
Brian_B's Avatar
Brian_B
Thanks George. As far as I can tell....almost everything on this truck is how it came out of the factory (or like factory). It is definately 12 V negative ground. I just had the charger on it this week.
