timing on a 75 390
Old Sep 25, 2001 | 07:52 AM
fordmaniac21's Avatar
fordmaniac21
timing on a 75 390
does anyone know what the timing should be set at, i have a 75 f-100 4x4 with a 390, 4 barrell edlebrock carb and a comp cam. all of the books i have say look on the sticker under the hood. well i have two probolems, 1) sticker aint there, 2) the truck came with a 360.can anyone help? the truck is runnin like crap and backfireing and i think that might be the problem. it backfires so much that it stalls the engine out.another thing , does anybody have a vacume chart for the vacume lines? that sticker is missing also.
Paul E Goodman III
'75 FORD F-100 4x4
390 4 barrel edlebrock, high-rise manifold, comp cam
16/38.5x15 super swamper TSL
Old Sep 25, 2001 | 09:49 AM
buzzard's Avatar
buzzard
timing on a 75 390
Start at 10 degrees BTC and tweak from there.
Old Sep 25, 2001 | 10:15 AM
fordmaniac21
timing on a 75 390
ok ill give that a try. hope itl work
Paul E Goodman III
'75 FORD F-100 4x4
Old Sep 26, 2001 | 01:47 PM
fordmaniac21
timing on a 75 390
hey what do ya know it workd.the timing was set at about 0. i set it at 10 then up to 12 to smooth it out a bit. after adjusting the idle mixture on the carb everythings fine. the truck has more power now. well seems to anyways. thanks for the hepl. does anyone know where all the vacume lines go from the intake manifold?????
Paul E Goodman III
'75 FORD F-100 4x4
Old Sep 27, 2001 | 10:06 AM
buzzard's Avatar
buzzard
timing on a 75 390
I don't have too many on my '68 390. One to the transmission modulator; one to the distributor vacuum advance; one to the brake power booster and one to the PCV valve.
Old Sep 27, 2001 | 10:51 AM
beartracks's Avatar
beartracks
timing on a 75 390
Don Vito
Sep 16, 2015 09:08 AM
montrealford
Feb 7, 2015 04:51 PM
POPAJON
Nov 23, 2014 12:14 PM
sweetlou1
Oct 23, 2013 03:42 PM
Mullholland_F100
15
Sep 6, 2013 02:43 PM
