moderate 390 build advice
Old Sep 4, 2013 | 05:42 PM
Mullholland_F100's Avatar
Mullholland_F100
Hi, I'm doing an install on my 67 390 this weekend and just wanted to see what you experts think. I'm installing a Edlebrock RPM intake, comp roller cam 270/276 (kit), new valve train, edlebrock 4bbl 650 thunder series carb, msd dist, new high flow air intake, sanderson ff427-bec shorty headers, 3" flowmaster exhaust.
This will be on an otherwise stock 390. I was going to go a bit bigger on the cam, but wanted low rpm response and did not want to mess with a stall or tranny at this point. This is all with a C6 auto trans. This is in my 56 f100. Will be adding other non engine goodies too (disc / power brakes, new wood in bed).
What do you guys thing I can expect from this? FYI: this will be for a weekend warrior truck.
Does this sound like a decent build? Should I change anything that sounds way off?
Old Sep 4, 2013 | 06:45 PM
69cj's Avatar
69cj
Personally I'd got with the Holley street Avenger 770 cfm electric choke. Has worked extremely well on my 428 cj. Much better than the stock 735 cfm carb. Aside from idle adjustment it was install and go.
Old Sep 4, 2013 | 07:06 PM
Mullholland_F100
I was on the fence between Holley and Ebrock. I was also undecided on size and figured for my build anything over 650cfm would be a waste. I went with ebrock for the secondary adjustment and the fact that the person doing the install with me has and likes that carb.
Old Sep 4, 2013 | 07:29 PM
69cj's Avatar
69cj
You'r choice. Hope it works out well for you.
Old Sep 4, 2013 | 07:46 PM
Mullholland_F100
You think 650cfm is too small? Will be stock besides what's listed above.
Old Sep 4, 2013 | 08:24 PM
MIKES 68 F100's Avatar
MIKES 68 F100
What CR on the 390 ? truck 390 with stock pistons could be an issue
Old Sep 4, 2013 | 09:31 PM
Mullholland_F100
Well it's a 1967 4v which was 10:5:1. Don't know exactly what it came out of, but according to the codes it was made it 67. But I have not pulled the heads to confirm the cr.
Old Sep 5, 2013 | 09:38 AM
MIKES 68 F100
ok , you should be ok with 10.5:1 lol
Old Sep 5, 2013 | 11:14 AM
69cj's Avatar
69cj
10:5 to 1 will more than likely require premium fuel to get the max out of your timing. My 428 cj is 10:6 to 1 and requires premium unless I severely retard the timing which defeats the purpose of a high compression street engine.
Old Sep 5, 2013 | 09:29 PM
montana_highboy's Avatar
montana_highboy
'67 could have also been a 9.5:1 or 10.1:1 C/R
I would of confirmed the C/R before purchasing a cam...
Old Sep 6, 2013 | 12:50 AM
85e150's Avatar
85e150
'67 4v would be 10.5. 2bbl motors were 9.5. This assumes it was a 4v motor as OEM.
FE Series Engine Specification Chart
Old Sep 6, 2013 | 02:41 AM
baddad457's Avatar
baddad457
With that cam it'll probably do OK running 89 with 12* initial timing. Might even work with 87. I would try it first on 89, then see if it pings or not. If not, feed it some 87 and see how it goes. Don't understand the thing about the adjustable secondaries on the E'brock carb, Holley's are every bit as adjustable there as well. With the RPM, you'll need to pull the intake locating pin out of the block, then set your gaskets up, then set the intake in place. Then before bolting it down, stab the distributor, get it seated all the way in, then torque the intake down.
Old Sep 6, 2013 | 12:58 PM
montana_highboy
I was using this chart Major Engine Specifications -- The Ford V-8 Engine Workshop as my reference material.
Old Sep 6, 2013 | 01:06 PM
85e150's Avatar
85e150
Hhhhm, don't see a 4v 9.5 390 there.... Anyway, OP has his answers methinks....
Old Sep 6, 2013 | 01:49 PM
montana_highboy
Nor do I, that's because one didn't exist.
I never mentioned 4v in my post, the OP did...
After five decades any intake could be on his 390, hence my recommendation to check the C/R
