Catalytic Converters
Old Sep 27, 2001 | 10:48 AM
BEAVER's Avatar
BEAVER
Another question I forgot to add to my last post. My truck is a 1977 F-250 with the 351-M. My question is whether or not these trucks had catalytic converters on them when they were made. The current exhaust on the truck is rotting away and needs to be completely replaced. The truck does not currently have cats on it. When I called around looking for exhaust prices, two shops told me that the truck will have to have cats put on it at a cost of $300 a piece. When I told him the age of the truck, and that I don't believe the truck ever had cats, he told me Ford started putting them on in 1975. I am pretty sure they werent there in the first place, and I'm not going to put them on. Is there a way to tell by the VIN if there were cats on it? I don't mean to be a pain with all these posts, but this is my first Ford PU and the only way I'll learn is to ask questions. Thanks to everyone who has responded to my previous posts.
Brendan
1977 F-250 4x4
351M / 4 Speed
33" BFG Tires
Red
Old Sep 27, 2001 | 10:52 AM
beartracks's Avatar
beartracks
It was based on weight initially. I don't think yours had them. Mine did.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Sep 27, 2001 | 12:10 PM
BigBrownTruck's Avatar
BigBrownTruck
Those years were a mix of Cat and Non cat.... somewhat dictated by the size of truck and what state it was destined to be sold in. A giveaway about whether your truck was a Catalyst truck would be: gas gauge has Unleaded Gas only printed on it..... Gas filler has same decal...... engine has it's original sticker that either starts out on top w/ the words Catalyst or NonCatalyst apparently the VIN has this in it for a definitive answer if you know how to decode it.
BBT
Old Sep 27, 2001 | 02:41 PM
78f250's Avatar
78f250
I don't think the 3/4 tons had cats....
Old Sep 27, 2001 | 03:58 PM
rwjr's Avatar
rwjr
true about cat and non cat trucks in late 70s....a sure-fire way to know if you have to have them is to check your filler neck...if it has a restrictor plate, with the little metal flapper, it is supposed to have cats....if it is a wide-open filler, cats are NOT supposed to be there....the restrictor is to prevent the insertion if the larger nozzled leaded fuel pumps...i ran into the problem of having to install cats on a 79 bronco i had....with the restrictor...i had a wide open filler sittin around from a tank replacement on another one, so i installed it, and went back and passed inspection....
Old Sep 27, 2001 | 04:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The neighbor to me has a 76 stock with no cats and a 75 stock with cats. F-100's BTW
Josh
Old Sep 27, 2001 | 09:37 PM
supercab78's Avatar
supercab78
It all depands on the GVW capacity. I think some half tons may not have had CATS. Don't know of any 3/4 tons having them. Your fuel gauge will say unleaded fuel on for the CATS
Old Sep 30, 2001 | 02:02 AM
ludis's Avatar
ludis
F100's got cats early on. The F150 (with a slightly higher GVWR) was introduced at that time to avoid the cat requirement - the GVWR was above the cutoff point for cats. F250's and F350's certainly had even higher GVWR's and hence no cats for a long time. (A local wrecking yard recently had an '86 F250HD with stock cat-less exhaust.)
Ludis
Old Sep 30, 2001 | 05:56 AM
fatdaddy's Avatar
fatdaddy
texaskid22
Oct 17, 2011 11:38 PM
78JUS4U
Dec 23, 2009 01:16 PM
Ford02F150
1997 - 2003 F150
35
Feb 6, 2006 09:55 AM
hornet258
13
Dec 30, 2003 06:27 PM
majkowskid
Exhaust Systems
Mar 10, 2003 07:25 PM
