gold coolant
Old Jan 13, 2006 | 08:37 PM
  #46
hoss1273's Avatar
hoss1273
Question
Have to change my water pump this weekend and I was going to change to ELC but now Im all confused !!
Old Jan 13, 2006 | 09:26 PM
  #47
clux's Avatar
clux
Originally Posted by blown99
If your new antifreeze is ethylene glycol based you will be alright (although your ford owners manual says to not mix the two). It is when you switch from glycol based to the RED (dexcool, texaco extended life antifreeze, etc.) that you will have the problem. The o-ring gaskets were getting eaten up/pitted after the swithc from glycol based to red elc. As I stated earlier, the units that came trough from the factory with the Red elc had virtually no leaks. The leaks were only/mainly the units that were switched. I think navistar had a section in there TIPS book on this subject, I'll see if I can locate. None of this is an opinion but rather facts compiled over a 4-5yr period on a line set of over 250 identical vehicles with the only difference being the coolant type. If I could access the navistar web site from this computer I would copy the list of failures for you all to see. You'd probably want to get rid of your trucks though.
Tratitional silicate coolants (what we think of as the "green" stuff), OAT coolants (dexcool), HOAT coolants (G0-05 and motorcraft premium gold), NOAT coolants (Rotella elc, CAT elc, etc) are all ethylene glycol based (about 90+% ethylene glycol in the jug). The only difference is in the anti corrosion additive packages.
The only non-ethylene glycol coolant I'm aware of is Evans, which is also ok for engines as far as compatability goes.
Color makes no difference, it is simply a dye. You can get any of the above coolants types (except Evans) in purple, green, yellow, red, orange or just about any color you want. My Wife's Concorde has orange coolant in it, but it's not dexcool, and the cooling systen is not dexcool (OAT) compatible.
Everything I've read indicates that HOAT, NOAT, and traditional silicate coolants are all compatible with our 99.5+ cooling systems. The older engines need to stick with tratitional silicate coolants.
If you're putting OAT (dexcool) coolant in, you are indeed going to have problems.
Old Jan 13, 2006 | 09:50 PM
  #48
ford390gashog's Avatar
ford390gashog
clux,
i emailed SOPUS to find out on the shell elc, i asked if it is dexcool based. they said dexcool is general motors trade name, but that it was made using the same base but they could not say it is dexcool base. as that would infringe on trademarks.
ok did some more digging, it turns out shell makes a dexcool based ELC and a glycol based coolant.both are the same color and same bottle just different part numbers.here is the specs for the glycol based one.
http://www.shell-lubricants.com/prod...RotellaELC.pdf
Old Jan 13, 2006 | 10:03 PM
  #49
clux's Avatar
clux
That's correct ford390, they all (except Evans) have the same base (ethylene glycol).
The difference, as I said before, is the additive package.
Old Jan 13, 2006 | 10:06 PM
  #50
ford390gashog
but what about the rotella dexcool based ELC? it uses OAT. that would be bad to use .
Old Jan 13, 2006 | 10:11 PM
  #51
clux's Avatar
clux
Right again, ford390. You should not use OAT coolants in out engines.
But OAT coolants are still ethylene glycol based.
Old Jan 13, 2006 | 10:13 PM
  #52
hoss1273's Avatar
hoss1273
Clux, You say the OAT is Dexcool ??? The product I am looking at is Peak final charge global ELC 50/50 ,listed as OAT
(Organic Acid Technology ) its properties are
50% Water
45-49% Ethylene Glycol
0-2.5% Diethelene Glycol
Do you think this is ok in my 2000 ?? Thanks
Old Jan 13, 2006 | 10:14 PM
  #53
ford390gashog
ok just checking.so then when members buy rotella elc make sure to get the 94060 and not the 94060 dexcool. i wonder why rotella did not make these look different. this could cause confusion and the wrong coolant may be used by mistake. the packaging looks the same just a different part number.
  #54
hoss1273's Avatar
hoss1273
Sorry ,You were posting while I was typing ,that answers my question. Thanks
Old Jan 13, 2006 | 10:18 PM
  #55
clux's Avatar
clux
That's the most important point out of this whole thread, ford390. You shouldn't choose your coolant based on the color, because it doesn't mean anything.
Old Jan 13, 2006 | 10:38 PM
  #56
rray32539's Avatar
rray32539
Originally Posted by clux
Go over to TDS and post that diesel ELC's are no good in the 7.3.
But put your flame suit on first.
Like we really care what those north ends of southbound horses think?
Old Jan 13, 2006 | 11:10 PM
  #57
SpringerPop's Avatar
SpringerPop
Those folks are not very civil any more. Lotsa' hostility goin' on over there. Even Hutchinagusta has moved on.
Too bad he didn't come here........
Pop
Old Jan 14, 2006 | 08:18 AM
  #58
blown99's Avatar
blown99
That is what I have been trying to get at. Go to the automotive section of walmart and look at all the different possibilities. Unless you really know what you are looking at you could unexpectedly put the wrong coolant in and cost yourself a lot of money in the future. Something needs to change (by the coolant manufacture) to prevent confusion when the typical homeowner goes out to buy a gallon to top off there system.
Old Jan 14, 2006 | 10:39 AM
  #59
Fords4Me's Avatar
Fords4Me
I found this, and it helped me a little. Atleast now I know why there's 2 reds.
http://www.filtercouncil.org/techdata/tsbs/05-2.pdf
Old Jan 14, 2006 | 10:51 AM
  #60
Kwikkordead's Avatar
Kwikkordead
Fords4me that did help.
After all this is that has been said in this thread, I think I am going to stick with the Shell Rotella that I have in my truck now. Just about every problem that I have read about is when different coolants were mixed into the cooling system and driven that way. Mine was flushed for a good half hour with a hose running the whole time after I drained the system and removed the block drains. There is no way that there is anything but Rotella in my system. Time will have to prove me right or wrong. Plus I have no intention of leaving the coolant in there forever. Knowing me, I'll most likely have changed it out within 5 years because I am just paranoid that way.
Blown99 I want to thank you for your input in this thread, the voice of experience has great value.
