Speedometer Problem (cleaning?)
Old Jan 22, 2006 | 01:19 PM
subford's Avatar
subford
Red face
Originally Posted by John7894
FWIW, I have installed a 93 cluster in my 94.........
i think if they are different the battery will not charge or the voltmeter will not work....
OK, I think you may be right. I was looking at the book and saw two Plugs, one black and one gray with differnt pinouts. I did not know that there were three sockets in the cluster and it takes both the black and gray plugs.
Sorry
Old Jan 22, 2006 | 01:25 PM
KW160's Avatar
KW160
Originally Posted by subford
NOT TRUE, at least the 1995 FORD Wiring Diagrams, 1995 FORD Electrical and Troubleshooing Manual and the 1995 Ford Shop Manual all say they are not the same.
I and many people on this forum have swapped tach for non-tach clusters with no wiring change...................
Old Jan 22, 2006 | 07:00 PM
alz's Avatar
alz
I had(have) same problem. PSOM is good but the speedo still wavers. I have the Ford TSB article no. 96-21-11. "Any slight dents, chips, etc., in either the exciter ring or VSS will create needle waver. Measure air gap between the VSS and exciter ring. It should be 0.38-0.51mm (0.015-0.020")."
I regapped the VSS and exciter ring and all but eliminated the problem. I still have a bad exciter ring, but that won't be replaced until I need to tear the rear end apart.
Old Jan 22, 2006 | 11:05 PM
John7894's Avatar
John7894
How did you regap it? I plan to drain the rear soon before I sell the truck and look at it. I want to fix all of the little things before I sell it.
Old Jan 23, 2006 | 07:03 AM
alz's Avatar
alz
I just used a file on the sensor so it would sit lower in to the diff. You could also grind(file) the diff where the sensor seats. But plastic is softer than steel.
50trucking
Sep 23, 2014 03:13 PM
boarhawg
1997 - 2003 F150
Apr 7, 2011 10:34 AM
dino360
1978 - 1996 Big Bronco
Jan 20, 2011 08:28 PM
kpoly2
16
Aug 30, 2007 11:37 PM
Mud_Covered_Ford
Jan 14, 2003 10:23 PM
