Sponsored by: Real Truck
Brakes
Old Jan 10, 2006 | 04:40 PM
xnorp's Avatar
xnorp
Brakes
I have a F-250 Super Duty 4 WD I am need to do the brakes on it have done disk brakes on other stuff but not on my Ford SD is there anything that I need to know that is different? I understand the emergency brake is inside on the real and it is a shoe. Just wondering if there are any things that I should be aware of thanks.
xnorp
Old Jan 10, 2006 | 04:47 PM
bryyce62's Avatar
bryyce62
If you're looking for some good quality rotors, give ART a looksee. Not the cheapest, but I'm a happy customer.http://member.newsguy.com/~nutech/frames.html
b62
Old Jan 10, 2006 | 06:29 PM
mattd17's Avatar
mattd17
whatever you do, i would not buy ford parts..... i am rather happy with NAPA's "best" option. yes, the e-brake is a shoe/drum stlye built into the inside of the rear rotors. the job itself is real easy, just BE SURE TO CORRECTLY TORQUE YOUR LUG NUTS!!! otherwise, you will soon be doing the job over. also, check your calipers to make sure they are still good, and clean off your slide pins and grease them to keep everything sliding good and not binding. goodluck !!!
Old Jan 10, 2006 | 06:41 PM
RushN350's Avatar
RushN350
Like mattd17 said, keeping everything really clean is important. But other than that there the easiest brakes I've ever changed
Old Jan 10, 2006 | 06:46 PM
xnorp's Avatar
xnorp
Thanks everybody for the replies.
xnorp
Old Jan 10, 2006 | 08:33 PM
99f350sd's Avatar
99f350sd
Open the bleeders and flush some new fluid through the system, always a good idea.
Some guy's open them when pushing the pistons back also.
Dick
xnorp
13
May 1, 2012 05:49 PM
xnorp
Jul 23, 2011 03:53 PM
xnorp
Oct 11, 2006 05:26 PM
xnorp
Mar 16, 2006 02:43 PM
xnorp
Jul 4, 2005 07:16 PM
