after i replaced my thermostat my temp started fluctuating(overheat/cooldown while driving) i think it's my thermostat sticking, i also replaced my radiator at the same time
I've started to get a temperature reading that goes all over the place.
I'm sure it's the stat. All I can say is don't buy the cheapest.....get a Motorcraft.
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
If you replaced the radiator, you might have an air pocket still trapped in the system.
I keep hearing about air pockets, yet somehow over the last forty years we never had such a problem. Just put coolant and water into the radiator and GO!
In 50 years of vehicle ownership/maintenance I've never seen any problem I could attribute to an "air pocket". I suspect, as rough and irregular as the water passages in an engine are, turbulent flow would remove any air initially trapped within a matter of a few minutes after the thermostat opened.
It grounds through the temp sender. When changing the stat it may have been disturbed causing erratic readings. Check the connection, make sure it's sound.
A sticking thermostat will most often stick in one position so I doubt that's it.
I hope no one minds if I jump in here on the subject of air pockets...
When you drain your cooling system you get air in your engine's coolant passages. When you refill your system the air from the engine is trying to escape into the radiator through the thermostat. If your t-stat is good it will block the air from exiting. When the radiator is full there could still be air trapped behind the t-stat. It takes longer for the t-stat to open when it is not in direct contact with hot water so you could have a chance to overheat. Once the t-stat opens, the air bubble is gone and should operate normally after that. That's when you should let it cool down and top off your coolant.
I doubt an air pocket is the problem with vhswrestler2005's truck, though. It sounds more like a gauge problem or it could simply be low on coolant.
I agree with that.
Many newer cars though are having air pocket problems that don't disapear, apparantly because the radiators are a lower profile, the air seeks the highest point which is in the engine, instead of in our trucks where it's the filler neck.
It could aslo be your fan clutch? I know mine whent bad, and would overhead wile in town... but be perfectly fine past 30mph.. So i put an electric fan in there... problem solved.
