General Automotive Discussion
Platinum Plug Differences?
Old Jan 9, 2006 | 06:51 PM
markjw's Avatar
markjw
At a department store, I bought a set of Autolite platinum sparkplugs for the wifes '97 astro van thinking all platinum plugs are pretty much the same... I paid about $12 for six of em.The guy at NAPA, who is pretty knowledgable, says I should only use the AC platinum plugs otherwise I may burn up the coil?????? Thats fine and all except AC plugs are $6 apiece and I all ready have the autolites...Any thoughts or ideas appreciated.Thanks,Mark.
Old Jan 9, 2006 | 08:38 PM
Hootbro's Avatar
Hootbro
Opinions on spark plugs are like politics and religion discussions. With that said, here is my view. Just about any name brand manufactuer of Platinum spark plugs makes a good one. So long as you are using what actualluy cross references to you vehicle, you should have no problems. Main thing to be carefull is when gapping a platinum, is to do it easy with your gap tool and not flake any plating off the prong end and to not crack or break the center electrode insulator material. 90% of what you hear bad about plats is mainly due to installation error or wrong type used for application. The two or four post ones mainly are for taking you money versus actual performance gain. I have used mainly BOSH plats over the years in about 15 vehicles with no problems but have used Autolite plats from time to time with no problems also.
Hootbro
Old Jan 9, 2006 | 11:22 PM
rebocardo's Avatar
rebocardo
I do not know about that, I do know from working at a Chevy dealer in the 80s, up to the present day doing a Chevy every once in a while, many emissions driveability problems went away once I took the aftermarket plugs out and put the correct app. Delco/AC plugs in.
Maybe I just gap them better :-)
I doubt you could burn up a HEI coil in a Chevy, it is pretty much bullet proof.
Old Jan 9, 2006 | 11:27 PM
fbodyfan's Avatar
fbodyfan
The only time plug selection matters is in hopped up high horsepower (especially nitrous and supercharged) motors. Some plugs get hotter than others. I think platinum plugs get hotter than iridium plugs, and it becomes a factor in detonation. I think he was just tryin to sell you a set of plugs, I really doubt it matters.
Old Jan 9, 2006 | 11:32 PM
ford390gashog's Avatar
ford390gashog
they guy at napa has no clue. but he is just recommending the oem parts like the computer lists. just use plugs with the correct resistance for your application.
Old Jan 10, 2006 | 04:09 AM
markjw's Avatar
markjw
Thanks for all the good info. I'll go with the autolites for now and keep an eye out for emissions and other problems.Thanks again,Mark.
Old Jan 10, 2006 | 04:10 AM
ford390gashog
yep no prolem
Old Jan 10, 2006 | 03:02 PM
jimandmandy's Avatar
jimandmandy
The only problem with the cheap Autolite platinums is that they do not last any longer than standard AC's. This was my experience with a 1994 4.3 GM V-6. Check them at about 30,000 miles and they will be worn out. Other than that, no big deal. They are not going to damage anything as long as the heat range is correct.
If your engine has no distributor, just coil packs, you need the more expensive double-platinum plugs if you expect them to last a long time. That is because the polarity of the spark alternates and the ground electrodes may burn away early. With a distributor ignition, the center electrode gets most of the wear.
Jim
Old Jan 10, 2006 | 06:09 PM
Rockledge's Avatar
Rockledge
Ford no longer recommends the DP (double platinum) series for its DIS/EDIS waste spark systems, instead the newer Motorcraft FM (fine wire platinum) series plugs are now specified as the OEM replacements. I don't think Motorcraft even has a line of DP plugs anymore, although some of the larger parts houses may still have some in stock. Autolite still has a DP line of plugs, I believe.
saintthomas
3.0L V6
80
Feb 15, 2023 10:25 PM
John with beastly 302
Nov 20, 2011 09:50 PM
wicker7878
1983 - 2012 Ranger & B-Series
Apr 18, 2009 11:59 PM
Aftrmidnite
Modular V8 (4.6L, 5.4L)
Jun 4, 2008 03:55 PM
Hank79
Oct 17, 2003 11:06 AM
