I did a search and came up with different opinions on what steering columns will work on 73-79 ford trucks. I've got a 76 F250 4x4 with auto trans that the column needs replaced. I dont need a tilt, but will any F150-F350/ bronco work as long as its an auto column? Whats the difference between 2 wd and 4wd can they interchange? Thanks
David
From my experience (I just did a auto to manual swap) the 2wd and 4wd columns will not interchange. The 4wd has a shaft coming out with 2 sets of splines on it that the steering shaft couples to. The 2wd has a piece pressed or welded onto the end of the shaft to attach to the ragjoint piece (not sure on the terminology).
in my experiances that doesnt come off,and i changed the center shaft quiet easy remove steering wheel and theres a c clip holding it then it just comes out.
