involuntary choke
Old Jan 8, 2006 | 03:12 PM
nick65f100's Avatar
nick65f100
involuntary choke
My 63 I6 daily driver is sliding into choke as im driving it. It only seems to do it at high rpms but I know im pouring gas out on the road, as each time i stop im running about 1700 rpms and the choke button is about a half inch out from the dash. Its gotta be something simple right?
Thanks,
Nick
Old Jan 8, 2006 | 03:53 PM
66beater's Avatar
66beater
Broken, worn out, missing, or malfunctioning return spring. Which carb is it?
Old Jan 8, 2006 | 06:32 PM
jd_sylvia's Avatar
jd_sylvia
Nick if I read this correct you have a manual choke. It shouldn't move that easy mine stays put but it also takes a bit to move it. I have even worked at cleaning the cable just to get it moving easy. I don't know if there is an tension adjustment or not maybe someone here can help us out. If you tighten the cable clamp tight maybe it will help hold it.
jd
Old Jan 8, 2006 | 07:09 PM
nick65f100's Avatar
nick65f100
sorry its a holley 1 barrel, and i know what you mean by it takes a bit to move it jd. I really havent messed with it much but i did tighten the cable clamps and it didnt change much. Normally its no big deal but it looks like Ill be driving on the freeway for a couple weeks and its really annoying and costly.
Old Jan 8, 2006 | 07:24 PM
phat56's Avatar
phat56
You could try installing a spring which would hold the choke open if the vibrations are causing it to close.
Old Jan 8, 2006 | 08:31 PM
jd_sylvia's Avatar
jd_sylvia
Good call phat. I think adding a spring may be a good fix.
jd
Old Jan 9, 2006 | 04:46 AM
jowilker's Avatar
jowilker
Maybe the cable is worn out, don't know why it's being pulled back on though. You can find replacements at your favorite parts house. The pull **** probably will be different.
John
yabadaba
May 15, 2016 10:29 AM
Adam Woolridge
Nov 29, 2015 08:27 PM
Mdc9966
Sep 16, 2015 11:20 AM
DaytonaTunnel
Apr 11, 2012 06:02 PM
Truckin4life
Aug 10, 2008 09:44 PM
