6SPD fluid?
Old Jan 8, 2006 | 11:39 AM
pbr man's Avatar
pbr man
6SPD fluid?
I have a '99 F350 4x4 7.3 PSD with a 6 SPD tranny and my owners manual says to use only Mercon ATF. I was wondering if Dextron III is compatable or if I have to go with the Mercon?
Old Jan 8, 2006 | 11:53 AM
wlihntr's Avatar
wlihntr
most mercon ATF will be mercon/dextonIII rated, thats the stuff you want
Old Jan 8, 2006 | 12:15 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I suggest a synthetic Mercon.....Quiet and smooth.
Old Jan 8, 2006 | 02:04 PM
pbr man's Avatar
pbr man
I use Conklin synthetics in all my vehicles. I started using them over 10 years ago in my logging trucks and highway trucks, Peterbilt and Kenworth with 3406 Cat motors. I gained 1/2 mile per gallon average fuel mileage- 700 gallons per year savings- and dropped the tranny and rearend temps between 65-85 degrees. I also use Conklin oils in my personal vehicles and have had excellent service with them. The ATF I have is Dextron III and would like to use it in my 'new to me' Super Duty and need to know if that will replace the Mercon?
Old Jan 8, 2006 | 02:38 PM
1997F-350's Avatar
1997F-350
i just replace mine about a month ago with royal purple synthetic atf....didnt work so hot....
found out later they make a special atf called "ROYAL PURPLE SYNCHROMAX" specially designed for manual trannies that require atf...
i put that in yesterday.....works 10x smoother now..even though mines a zf5 they still call for the same fluid.....it was about 30 buck for 4 qts.. i am sure the zf6 holds more seeing how you got a cooler...
fwiw good luck.
Old Jan 8, 2006 | 05:57 PM
cookie88's Avatar
cookie88
FTE Emeritus
While I doubt it would hurt anything, I don't believe anything other than Mercon is approved by Ford....not even Mercon V
Old Jan 8, 2006 | 08:31 PM
barebackjake's Avatar
barebackjake
kinda funny ford manual says mercon v
but the tranny tag and zf says FULL SYNTHETIC ONLY
i run amsoil atf in mine works great.
Old Jan 8, 2006 | 08:35 PM
ford390gashog's Avatar
ford390gashog
''kinda funny ford manual says mercon v
but the tranny tag and zf says FULL SYNTHETIC ONLY''
i think you need to reread it. mercon v is for use in the 4R70w and the 4R75E.
Old Jan 8, 2006 | 11:42 PM
pbr man's Avatar
pbr man
I just went to ZF 6Spd web site for technical specs and it says to use dextron III, Mecon , or full synthetic so I can use the oil I have. Thanks for the reponses. This site has helped me in a lot of ways with all the good tech advice from the people here. Thanks again. Eric
Old Jan 9, 2006 | 06:46 AM
dunbar15's Avatar
dunbar15
I used mobil 1 ATF synthetic, is this OK ?? Have 140K on tranny with
no problems that I know of .. Knock on wood..
Old Jan 9, 2006 | 11:00 AM
dunbar15's Avatar
dunbar15
oOOPS , YOU GUYS ARE TALKING ABOUT A MANUAL TRANS.. SORRY FOR THE MISTAKE.. ANY THOUGHTS ON THE MOBIL 1 ATF.. THANKS
Old Mar 6, 2006 | 09:15 PM
PowerStrokeMe's Avatar
PowerStrokeMe
Where do you get your tranny fluid at?
What about for transfer, front, and rear differential fluid?
CurtisFT
Feb 24, 2013 08:24 PM
Pitcrw6
Mar 13, 2011 06:22 PM
60RatRod
Dec 6, 2008 06:15 PM
skilife17
1997 - 2003 F150
Apr 26, 2007 03:46 PM
Joe Finn
1997 - 2003 F150
32
Mar 18, 2004 02:32 PM
