por15 is good, but I like eastwoods "rust encapsulator" better(they have silver, red,clear, or black). epoxy works best for frames if you decide to sand blast.
You may also want to check into chassis saver by magnet paints. this stuff works great. you can get in silver, gloss black, and satin black. The stuff is like powder coat when dry. they claim there product is best like all of them, but I have used on my frame and have been impressed.
I used POR15 and their chassis coat on my 70 crewcab frame and it came out nice, holds up and shines up good when I clean it. I'd recommend it to anyone, I'm sure all of them have their ups and downs. Anything is better than rust. I also used their engine enamel and it holds up well also, even on the heads.
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
bill hursh makes some of the best stop rust in it tracks paint it is better than por 15 because you dont have to prep the surface like you do with por 15 and when its dry you leave it out in the cold moist are and it becomes hard as a rock
