Heat doesn't work
Old Jan 7, 2006 | 04:37 PM
WhiskeyJack's Avatar
WhiskeyJack
Talking Heat doesn't work
Hey Folks! This is my first post here. I'm wondering how to access the heater core in a 1996 explorer 4.0. I think it's behind the glove box area.
Thanks! Driving with the windows down to prevent fog is kicking my butt!
Old Jan 7, 2006 | 04:58 PM
Backin72's Avatar
Backin72
You sure it's the heater core? Have you had the thermostat checked or replaced lately? I'd start with the thermostat first.
Old Jan 7, 2006 | 05:24 PM
WhiskeyJack
Talking
Not yet- I'm gonna check the thermostat tomorrow morning and all the fluids and tubes and stuff. It's probably the thermo, but I just want to be ready in case it isn't- I want to get it all taken care of tomorrow no matter what- no more freezing for me
Old Jan 8, 2006 | 01:48 AM
87 XLT's Avatar
87 XLT
Are the hoses to the heater core getting hot?
Is the temp gauge running where it normally does?
Old Jan 8, 2006 | 03:08 AM
Grsyhands's Avatar
Grsyhands
If the windows are fogging and you're getting that wonderful, sweet, disgusting smell inside the cab it's most likely the heatercore. I'd help you out with the access question but my manual only covers 97 and up. Good luck.
Old Jan 8, 2006 | 01:30 PM
WhiskeyJack
The temp gauge is fine.. There is no smell at all- the windshield fogs up because it's cold out. The hoses going into the firewall to the heater core are hot, it just blows at the ambient temperature. In fact when it's hot outside I don't think it blows cold either.
I'm starting to think that some shutter behind the dash is stuck closed. Any other ideas?
Old Jan 8, 2006 | 01:58 PM
Backin72's Avatar
Backin72
Could be the blend door then. Check this out.
https://www.ford-trucks.com/forums/s...ad.php?t=24962
Old Jan 8, 2006 | 03:23 PM
87 XLT's Avatar
87 XLT
Not sure, but I think the 97's were the first year that had the broken blend door problem
But regardless of that you need to figure out why the blend door isnt moving.
Could be a bad dash switch or a bad blend door actuator motor.
Old Jan 8, 2006 | 05:41 PM
WhiskeyJack
Thanks For the Link! That looks like it'll do the trick.
Old Jan 8, 2006 | 05:44 PM
WhiskeyJack
87, is the actuator motor a hard part to find?
Old Jan 8, 2006 | 06:20 PM
87 XLT's Avatar
87 XLT
Not sure exactly where under the dash the motor is, but if it's the same as a 97 It will have a 5 wire connector plugged into it.
BTW, take a quick look at the fuse list in your owners manual and see which fuse is wired to the blend door actuator & check that fuse.
Odds are that fuse is wired to other accesories also, are they working?
moejr
Electrical Systems/Wiring
Dec 5, 2016 09:58 AM
02 Super Duty Guy
Oct 7, 2014 05:39 PM
Patrick714
May 30, 2014 05:23 AM
AIbandit
36
Nov 28, 2011 07:02 PM
compaddict
27
Nov 23, 2009 04:15 PM
