radiator over flow jug
Old Jan 6, 2006 | 09:07 PM
X36's Avatar
X36
Hey everybody.I was wondering did ford ever produce a radiator overflow jug.On my trucks I just tied a antifreeze jug near the fan shroud and put the hose in it.Anybody in hear have any opinions on a need for a jug or not.Thanks
Old Jan 6, 2006 | 10:42 PM
timothy47129's Avatar
timothy47129
You could always use an overflow jug off an early 80s ford f150.It is a single tank with a divider in the middle to divide antifreeze on one side and windshield washer fluid on the other.I think thats what i will do on my 78 .
What an overflow/recovery jug does is catch the antifreeze that is expelled from the radiator.When the pressure inside exceeds the pressure rating on the radiator cap from heat like an extra hot day or towing. When the engine cools down and the pressure returns to normal it recovers the coolant back into the coolant system. Thats what i have been told.I could be right or wrong
Tim
Old Jan 7, 2006 | 09:36 AM
LxMan1's Avatar
LxMan1
Or you can purchase a universal kit at Autozone. I have used one before. I have an 80's model on my 77 now.
Old Jan 7, 2006 | 10:38 AM
thelonerangerxlt's Avatar
thelonerangerxlt
I installed an AutoZone universal kit on my 78 Bronco last year. It fits perfectly on the driver's side of the radiator support, with a short run of overflow tubing. You'll have to change out the radiator cap for one that seals on both lips of the radiator, in order for the overflow to suction back into the radiator.
Coolant recovery bottles are not as necessary on downflow radiators as much as on crossflow, but I still like the idea of having one. They prevent coolant from burping out when you stop, and allow you to fill the radiator completely rather than leaving an air space in the radiator top. More coolant equals slightly better cooling ability.....
TLR
Old Jan 7, 2006 | 12:39 PM
X36's Avatar
X36
Thanks Loneranger
Old Jan 8, 2006 | 12:52 AM
timothy47129
It gets old after a while people telling you,you have an antifreeze leak every time You shut off your truck on a hot day and it spits out.
Tim
Old Jan 8, 2006 | 11:20 PM
greenranger98's Avatar
greenranger98
i used 2 3inch pvc caps and a 12in long 3 in pvc pipe and drilled hole in top and stuck overflow hose into it and mounted it behind grill, dont laugh, it works!
Old Jan 9, 2006 | 01:28 AM
smandzak's Avatar
smandzak
My 79 F150 has a factory overflow. I want to say that I've seen them in reproduction catalogues like LMC too.
Old Jan 9, 2006 | 08:23 AM
76supercab2's Avatar
76supercab2
Some of the earlier trucks like my 76 didn't have an overflow tank. But they were designed to not have the radiator filled all the way up. The air gap on top of the tank took care of the expansion of the coolant. There was even a sticker on the rad support telling you to only fill the rad to the top of the core.
oldmerc
Aug 31, 2013 05:50 PM
Chevmn56
20
Apr 4, 2013 09:12 PM
xtrford
Oil & Lubrication
Aug 25, 2005 03:29 PM
2tone73
25
Jul 8, 2005 10:39 AM
DL
Jul 26, 2004 02:07 PM
