Explorer idling problems
Old Jan 6, 2006 | 10:31 AM
HHKev84's Avatar
HHKev84
I'm having a problem with my explorer. It seems as though when I start the truck up, it idles weird until the temp goes up. The RPM will flutter, from 500 to about 800, with barely a second in between each pulse. The entire truck will shudder until I begin driving, then after a few miles (or it warms up to about 1/3 of where the heat gauge is supposed to be), everything is fine. Horsepower lagging as well, it just doesn't seem to have the same power as before. Suggestions?
I already cleaned the carbon out of my IAC valve, checked it recently, and it's pretty clean still. I'm thinking air filter or something to do with the air intake.
2000 Ford Explorer XLT
86,000 mi.
4.0 L V6 SOHC
Old Jan 6, 2006 | 07:45 PM
bulldog3531's Avatar
bulldog3531
Does it only do it when it is cold? If so it could be the intake manifold o-rings. Do a search on the o-ring and see if this is your problem. Hopes this helps.
Old Jan 6, 2006 | 08:27 PM
black wolf's Avatar
black wolf
86,000 mi.
4.0 L V6 SOHC
Look into replacing your pcv valve. Mine did the same thing and i put a new one on and the idle smoothed out.bulldog3531 has a good thought of the o-ring idea too so look at both and see if it would help
Old Jan 7, 2006 | 05:58 AM
marragtop's Avatar
marragtop
If all else fails, pull the codes....
Old Jan 7, 2006 | 08:27 AM
HHKev84's Avatar
HHKev84
Thanks
Thanks for the replies, it's a good place to start.
Old Jan 7, 2006 | 07:53 PM
oshoguno's Avatar
oshoguno
Sounds like classic intake manifold o-ring problem. I had mine done over the summer and what a difference between this winter and last. The other symptoms of this are that the problem gets worse the colder it is and that it goes away when the engine starts to get warm. One thing you can get your mechanic to do is to spray your intake area with carb cleaner when it's cold to see if the problem stops for a minute then picks up again. Good luck.
Old Jan 15, 2006 | 11:37 AM
48Ford's Avatar
48Ford
2000 Explorer - what RPM should idle be?
Am having similar problem with idle on recently purchased 2000 Explorer XLT 2WD. What should RPM should idle be?
Old Jan 15, 2006 | 07:19 PM
oshoguno's Avatar
oshoguno
Warm idle should be 600-700rpm, cold idle should be 800-1100(very cold).
Old Jan 16, 2006 | 09:34 AM
48Ford's Avatar
48Ford
WOW, your answer was quick! What a great bunch of guys...now, I'm pulling a woman thing and asking more questions...
What should the ride height be for a 2000 Ford Explorer XLT 2 WD?
What should fuel pump pressure be for a 2000 Ford Explorer XLT 2 WD?
Where is the fuel injection pump pressure regulator on a 2000 Ford Explorer XLT 2 WD?
What does the fuel injection pressure damper do on 2000 Ford Exploer XLT 2 WD?
Old Jan 16, 2006 | 02:47 PM
oshoguno's Avatar
oshoguno
Hi, I should have mentioned that the idle rpms is when the truck is in drive with the brakes one. As for your other questions I am sorry but I can't help you there. Maybe a service manual (haynes) would be of help. Maybe someone else would be able to help you out. Good luck.
frdlvr35
Dec 13, 2011 01:43 PM
VonoreTn
Jan 24, 2007 04:09 PM
micklskot
Sep 15, 2006 10:10 PM
EK082
Oct 8, 2003 07:16 PM
jakerot
13
Dec 28, 2002 01:02 AM
