Security Light on Dash?
Old 01-05-2006, 08:04 AM
whtevr's Avatar
whtevr
whtevr is offline
The security light on my boss's 2005 F-150 Lariat is staying on whenever the trcuk is running. This light normally lights up on ignition and then turns off like all the other dash lights, but for some reason it is staying on now. Has anybody seen anything like this or know what could cause this?
This light is located on top of the dash right next to the windshield. It normally flashes when the truck is not running, I guess to deter theft.
Old 01-05-2006, 11:25 AM
InboundFX4's Avatar
InboundFX4
InboundFX4 is offline
I could be way off base but seems like I remember this means there could be a problem with the airbag.
Old 01-05-2006, 12:29 PM
DonsFx4's Avatar
DonsFx4
DonsFx4 is offline
Owners manual says that if light is blinking rapidly or on steady while engine is running, there is a problem with the PATS (security system) and it needs to get to the dealer for repair.
I would imagine its still under warranty, so let them deal with it.
BTW, I looked at my wiring diagram and the light finds its ground in the PCM. The PATS module provides an input to the PCM, so there must be some relay that gets tripped when a problem exists. The dealer should be able to scan the PCM for whatever fault code is being generated and take care of it. I couldn't see any input regarding airbags (that should be annunciated on the instrument panel).
Old 01-05-2006, 06:15 PM
onamission's Avatar
onamission
onamission is offline
Mine did the same thing for a few days and then went back to normal. The manual says the system may correct itself, so I'd tell him to wait a few days before he takes it in.
Old 01-06-2006, 04:07 PM
whtevr's Avatar
whtevr
whtevr is offline
Thanks for the help - the light went out, so he is just going to monitor it to see if it happens again.
rmalottwtes30
09-09-2010 06:51 PM
Selwoc
1983 - 2012 Ranger & B-Series
03-24-2009 08:00 PM
Munch
07-04-2006 05:26 PM
ColtM4
1999 to 2016 Super Duty
02-05-2004 02:53 PM
Quick Reply: Security Light on Dash?
