Recomendations on pillar mount guages?
Old Jan 4, 2006 | 08:42 PM
fridgeddiesel's Avatar
fridgeddiesel
I am thinking about adding a pyro/boost guage on my truck. Have a manual transmission so I don't think I need the tranny temp guage. Would like to mount them on the pillar. Any recomendations on suppliers of complete kits? Would like to make it as easy as possible.
30 or 60 boost guage?
97 F250 4x4 7.3L Powerstroke Superchips Perf-Tow
Old Jan 4, 2006 | 09:33 PM
stroker2's Avatar
stroker2
I would look at Diesel Manor, a site sponsor. Just click on their name on the left of this web page. They sell complete kits and also sell them with the pillar painted and the gauges mounted if you'd like. They also use ProPod a-pillars which I also like / recommend. I have and recommend the Isspro gauges because they closely match the gauges in the truck, they are back lit verses side lite and are "full" sweep (270*) verses 90* sweep. A 30 psi boost gauge is all you need unless you plan on adding a lot of power, then maybe a 40. Be sure to get a pre-turbo pyro. Check out all the individual gauges. You may have to call them to get the gauges you want in a kit since they only sell 99+ kits on line. They do sell the 94-97 a-pillars so I'm sure they will accomodate you. They provide great instructions and support. Have fun shopping.
Old Jan 4, 2006 | 09:52 PM
fridgeddiesel
Thanks for the info stoker2. Isspro guages seems to be what I have decided on and I'll go from there. 30 psi boost guage is the real missing bit of info. Thanks again...
Old Jan 5, 2006 | 09:20 AM
1997F-350's Avatar
1997F-350
dad and i run autometer 35 psi gauges....
pics of both in my gallery. i like his better they are the black ones.
regardless of gauge you go with...i would get an autometer pod. they look like the factory moulding.
ME AND MY DAD BOTH HAVE 5 SPEEDS WITH 2 HOLE PODS....CHECK IT OUT.
Old Jan 5, 2006 | 09:52 AM
1969fordguy's Avatar
1969fordguy
I have the Isspro gauges in my truck. The three gauge pod looks really good, maybe you could find another gauge to fit in it...
The gauges I have are backlit but not in green like the factory dash, do they make dirrerent colored lights for the aftermarket gauges?
Old Jan 5, 2006 | 06:39 PM
fridgeddiesel
Isspro makes a green cover for the lights that makes them the same color as the factory dash light I think they are .89 apiece. Diesel Performance Parts carries them. They are a sponser on the left hand side <---
Old Jan 5, 2006 | 07:56 PM
1997F-350's Avatar
1997F-350
my autometers come with green bulb covers also!!!!! and red.. or you can leave em off for clear.
Old Jan 6, 2006 | 07:12 AM
1969fordguy
Thanks for the tip on the covers.
Old Jan 6, 2006 | 05:07 PM
worm drowner's Avatar
worm drowner
Trailering
I have the Isspro gauges on my truck from Diesel Manor. Good people! I did get the pilar mount from Diesel Injection Service simply because they sell painted ones to match my interior. They are also good to deal with.
1969FordGuy,
Diesel Manor sells the green covers for $0.89 each.
Old Jan 6, 2006 | 11:33 PM
Phydeaux88's Avatar
Phydeaux88
The Isspro gauges with black background, white numbers and green bulb covers are a perfect match for the stock dash. One hint and I did it by accident, lost one of the green bulb covers at install time, I temporarily put the red cover on my EGT gauge. It really stands out makes monitoring EGT at night very easy. The "Temp" situation has become permanent.
Old Jan 7, 2006 | 05:12 AM
1997F-350's Avatar
1997F-350
that sounds like a good idea. i may have to try this also..seeing how none of the gauge faces or cluster and radio match anyways.
