ac pulley bypass
Old Jan 4, 2006 | 12:56 PM
childsplay's Avatar
childsplay
ac pulley bypass
I did a quick search and couldnt find much...
I have a 89 F250 w/ 460. The ac pulley and clutch are making horrible noises and have started smoking . The AC doesnt work so I dont want to replace the compressor and I dont want to pay $150 for new clutch and pulley.
Does someone sell an aftermarket bypass made for this year? I have found them for '90 and up but not for this year
will this one work on my '89? http://cgi.ebay.com/ebaymotors/AC-BY...spagenameZWD1V
Old Jan 4, 2006 | 01:42 PM
andym's Avatar
andym
Have you thought about buying a new belt for a non-A/C truck and re-routing it according to the diagram under the hood? If the sticker's gone, someone here will be kind enough to reproduce it here for you.
Old Jan 4, 2006 | 01:49 PM
childsplay's Avatar
childsplay
Napa doesnt have a nonAC truck in this year in their computers. By bypassing the ac comp. the tensioner doesnt seem like it would do its job and pinch the belt to the pulley
any other suggestions?
Old Jan 4, 2006 | 02:01 PM
frederic's Avatar
frederic
The serpentine belt for an AC truck is the same as a non-AC truck. What Ford does is slap on a large pulley in place of the AC compressor if there is no AC.
Either replace your compressor with the large pulley (junkyard item) or take your belt off, and run a string around the pulleys, minus the AC compressor, subtract 2", and that's your belt size.
Old Jan 4, 2006 | 02:31 PM
childsplay's Avatar
childsplay
I have two seperate belts, one runs the power steering and ac. If I run a belt only to the powersteering the tensioner doesnt seem like it would work... is that wrong?
Old Jan 4, 2006 | 02:33 PM
frederic's Avatar
frederic
I couldn't tell you without seeing it.
Take a picture, the best you can of the PS/AC setup.
I assumed oyu had the single belt setup, but obviously you do not.
childsplay's Avatar
childsplay
I also dont have any junkyards close to me that have anything I ever need. Is the pulley something I can buy aftermarket or find somewhere used?
Old Jan 4, 2006 | 02:44 PM
frederic's Avatar
frederic
Maybe on ebay, car-parts.com.
Without seeing what you have, I can only guess, but probably something like this:
http://cgi.ebay.com/ebaymotors/AC-BY...6908QQtcZphoto
Is your belt a "V" belt, or a serpentine belt? The above is serpentine, obviously.
Old Jan 4, 2006 | 03:01 PM
childsplay's Avatar
childsplay
that is the same link that I posted above
:edit: looks like the link is no longer valid
it says it will work for 90 and up, I just want to know if it will work for my 89
how do I post a picture of what I have?
its a sepentine belt
Old Jan 4, 2006 | 07:00 PM
frederic's Avatar
frederic
Okay, that's kinda funny.
You put the image on the internet somewhere, and post the URL to that image in one of your posts.
Or you can email me the picture and I'll do it for you.
Old Jan 5, 2006 | 12:14 PM
GWall's Avatar
GWall
I found an A/C bypass pulley for my '93 302 at Advance Auto Parts a year or so ago. It bolts on in place of the compressor allowing for the stock belt to be used. Cost was about $30 if I remember correctly.
Old Jan 5, 2006 | 01:45 PM
jbalestri's Avatar
jbalestri
Childsplay, there is adjustment in the power steering pump. I had the same problem and did like frederic mentioned with the string and minus 2". You can tighten the belt without any issues. I ran my truck this way for 2 years, until my wife decided she had to have a/c since she was pregnant this past summer.
Beware, you are driving on borrowed time. The compressor will seize and throw the belt. You will not have power steering once this happens and these trucks are a bear to steer without it.
Old Jan 7, 2006 | 06:49 PM
childsplay's Avatar
childsplay
for future searches...
I ended up bypassing the pulley all together like suggested with a 54" belt and everything is working great!!!
thanks for the help and suggestions
__________________
Old Mar 10, 2026 | 05:43 AM
patchjob's Avatar
patchjob
2nd Gear
The size for a bypass belt should be K060555.
If you know anyone else who is looking for this size, it should be this size.
Old Mar 10, 2026 | 05:45 AM
patchjob's Avatar
patchjob
2nd Gear
BTW, you will have to pull the tensioner out of the way a bit, try to find a larger wrench with a bit of leverage to use. Once installed, the tensioner will be in the same position it would be with the normal belt.
Dank Hill
Apr 25, 2016 02:32 PM
annaleigh
25
Mar 17, 2016 01:51 AM
BadDogKuzz
13
Mar 3, 2016 07:47 PM
sstouder
Feb 13, 2010 10:14 AM
ericfgs
Sep 30, 2009 03:49 PM
