Hello, I have a 2000 V-10 with 91,000 miles on it. After accelerating, when I take my foot of of the pedal and begin to apply gas gently, the engine hesitates and has a slight "jerk" to it. I changed the IAT about 2,500 miles ago and it went away for a bit. Now it is back. Any ideas? Does a bad IAT send fault codes I can get a reader and find?
Correction I changed the IAC (Idle Air Control valve) is there any error codes that it should show. Or, if there is a spark plug problem, would it give an error code?
Both of my 2000 V10s do the same thing, when you coast for a short time the torque converter unlocks and the and when you step on the gas the motor will rev up a little before it locks back up again, it feels like a hesitation but its not. I have driven some newer V10s and they don't seem to do it so it mite be just the earlier trucks that do it. You may also notice that when you let off the gas and coast the converter locks back up in a lower gear to help slow down.
Denny
My 2001 does the convert lock/unlock thing when you let off and then hit the gas again.
The only time you will notice the down shift is when you are running heavy and the computer goes into its tow mode.
You know, I did feel something that felt like a downshift once, after heavily abusing the poor thing with a load... Only did it once. I thought it was a hiccup
Anybody that doesn't think that they wont adjust to a load I'll let them drive my work truck 9400 lbs 24-7 and then disconnect the battery and drive it again, big difference.
