i have a 01 sd and i am having problems with the horn going off randomly. the only way to stop it is to pull the fuse, that was working fine until i park it for a couple of days then the battery goes dead. don't know if they are related. any suggestions?
Geee 2 in one night. You can pull the horn relay out. Some guy's have been having problems with possible water on the gem module causing all kinds of weird stuff happening. Leaking windsheilds is usually the problem. Batt going dead is related.
