Sponsored by: Real Truck
squeek inside cab
Old Jan 3, 2006 | 05:37 PM
OfficerDangle's Avatar
OfficerDangle
squeek inside cab
i got a 99 ext cab f250 and there is an annoying squeek coming from i believe the plastic on the passenger side door for the back seat(4 door ext cab). is it possible to remove the plastic from the door and clean it off or look for some loose parts. if so how do i get this peice off. thanks
Old Jan 14, 2006 | 03:04 PM
hozjob's Avatar
hozjob
To remove the plastics on the inside of the door on an extended cab you have to remove the two screws holding the window closer, they GENTLY pry back the plastic surrounding the window. Once you have that off remove the two screws and two clips from the lower unit and pull upward and it should slide right off.
fitz888
2004 - 2008 F150
Jan 23, 2009 05:27 PM
40LUTZAG
1997 - 2003 F150
Apr 27, 2008 08:09 PM
Jimmy Dean
1997 - 2003 F150
Dec 19, 2007 10:17 PM
wmwbutler
Dec 3, 2004 12:00 PM
dblakney
May 18, 2004 08:28 PM
