351W cutting out
Old Jan 3, 2006 | 01:34 AM
fmc400's Avatar
fmc400
MSEE
351W cutting out
I have a 351 Windsor in a '77 LTD with a strange problem. In general it runs fine, but every once in a while the motor will shake for a bit then kill. It will start right back up and the problem won't be there. The shake feels like a miss. The problem is sudden, rare to occur, and goes away when I restart. I've put a new coil on, and the fuel level in the carb is good. The choke is not sticking. I'd say a couple times lately, the engine feels like it has a slight miss when first started in the morning. This shaking then killing problem, however, has occurred when the engine has had time to warm up. I can't think of what could be wrong. Any ideas?
Old Jan 3, 2006 | 05:42 AM
ken75ranger's Avatar
ken75ranger
What do the sparkplugs look like? If they are good and the wires are good then check the distributor and duraspark module.
Old Jan 6, 2006 | 04:59 PM
fmc400's Avatar
fmc400
MSEE
In case this is of later use to someone, I pulled off the ignition module and had it bench tested at Autozone. Their machine runs about 8 or so tests and my module failed all but one. I replaced it, and the engine hasn't killed yet...I would also say the car seems to start easier. Hopefully this fixes my problem and thank you ken75ranger for responding.
Old Jan 7, 2006 | 06:33 PM
MustangGT221's Avatar
MustangGT221
Thanks for the follow up!
paintslinga2010
Dec 15, 2015 09:10 AM
D.K
13
Jun 27, 2015 03:11 PM
d450heavy
Jun 14, 2013 11:15 PM
7.3 Ex
Mar 13, 2011 06:27 PM
rdneckdeluxe
Aug 7, 2004 10:10 PM
