Looking for some guidance...
The truck is hard to start when cold. So hard in fact that without spraying starter fluid into the TB, I'll kill the battery trying to get it to fire. After the initial spray to get it to fire, it'll run on it's own. When it does start, it has a serious miss at idle. It shakes like crazy, and the passenger side of the engine seriously looks like it's trying to jump out of the bay. Probably a shot PS motor mount, but the shaking is extremely violent. Smooths out drastically over 1K RPM. Adjusting the timing only introduces more shaking as it becomes overly advanced/retarded. Even with the shaking, the truck will idle all day at roughly 700 RPM without having to keep it alive. The exhaust reeks, and being anywhere near the exhaust will cause your eyes to burn immediately. It's also burned through 1/4+ tank of gas, and I haven't driven it anywhere... It will go into gear fine. Sometimes the RPM will drop to 500 and the vibration will get worse but it will move under power, other times it'll smooth out completely because it stalls.
I have a few questions to help get this thing running better:
- This was originally a 2 tank truck, but over the years the front tank was removed. Is this a problem with there being no front tank/pump? Supposedly the truck was run like this for a while and did not have issues. I have no idea as to why the tank was removed, however. The switch still works properly, but pegs the fuel gauge when switched to the front pump.
- The Haynes manual has a different firing order listed for 1993 and earlier F150 5.0s than for the 1994 and later ones. The earlier firing order will not work on my truck but the later one does. Normally I'd just assume that perhaps either the motor or cam had been replaced some time in the past and was "upgraded", but I'm not looking to make any assumptions with this truck at this point. Is there any easy way to verify the proper firing order other than trying each to see which order works best?
Sorry for the wall of text, and thanks in advance for any help!
Could be a lot of things, bad spark plug wires, spark plug wires not all the way on the plug, fuel injector(s) not firing.
Have you checked the compression?
Have you checked for codes?
The truck came with some ridiculously long MSD 8.5mm plug wires. I haven't inspected them, but I think I'll replace them anyway for peace of mind. I did have to change the plugs this weekend, as the old ones were completely fouled and smelled of gas. I'll double check to make sure that I pressed the ends down completely on the plugs.
I haven't checked the compression. I'm hoping it's nothing internal, but I'll see if I can borrow my buddy's compression tester.
I'll have to look into getting an OBD1 scan tool to check the codes. The CEL doesn't light at all so I can't do a KOEO test unfortunately.
Ford 302 V8 (5.0L) | Specs & History
I personally would start by looking at the fuel injectors, everything you describe is telling me you're dumping fuel into the cylinders at least some of them are stuck open.
The other thing I'd look at is I'd pull the distributor cap and take a look at the towers and the rotor if they're corroded and the rotor edge is really rough, I'd change them. verify the firing order and timing by static, #1 piston on top of compression stroke and rotor pointed to #1 tower on cap.
It was definitely the HO firing order (1-3-7-2-6-5-4-8), and if I'm not mistaken it was listed as the correct sequence for 1994+ F150s. I'll double check once I get home. The HO firing order is also the only sequence that my truck seems to run off of.
The cap and rotor look good. I didn't see any corrosion on either (MSD replacements). One of the first things I did was to static time the motor. I verified #1 and wired everything else counter-clockwise.
As for the injectors, is there any way that I can test them to see if any are stuck open? A quick search shows that they are 19/lb injectors. Would there be any issue running a set of stock, pink-top injectors that I pulled from my 2002 Mustang GT a few years back?
you can check injectors by testing the resistance in the wires but isnt always accurate you can also do it the old fashioned way and use a screw driver as a stethoscope and listen for the ticking which will tell you its working but doesnt tell you if it's actually letting fuel through. I'd go to the autozone or advanced auto and rent the tool to test them the proper way.
Perhaps I should replace the coil as well as preventative maintenance. Even though I verified that I was getting spark, it wasn't anything to brag about.
I would've tried to get FP readings with the engine running but it wouldn't fire and with daylight fading and me being new to the neighborhood, I decided to call it a night.
This is starting to bring back memories of my old 5.0 Explorer that had a dead miss at idle. Luckily that was due to a brand new plug wire that was cracked under the boot.
IMO there is nothing in the codes that would cause the problems you have so go back to basics and make sure all plugs and wires are routed correctly and are in good condition, all cylinders have good compression, and the distributor is stabbed correctly at TDC on Cyl 1. And just to be thorough you are aware of how ford numbers cylinders? If it turns out your motor uses the HO firing order then it's not the original motor and that begs the question.. what else did the PO change? Hopefully he didn't use any wiring from the donor vehicle because there is no guarantee it is compatible with your truck and could cause problems with the injector firing.
